is there a reason for this..(oil gauge related).
Old Feb 18, 2002 | 07:05 PM
quikrpm'z's Avatar
Default is there a reason for this..(oil gauge related).
this is how my lines are set up, by my mechanic.
..................... line to the turbo.
block --OOOOO--T
.................... sender
those O's are looped together. The line is a braided line, he did it like this after that pipe that came with the autometer gauge kept cracking. Ive seen endyns way with one loop, but not this many loops. I just wanted to get your thoughts before i call him tomorrow.
[Modified by quikrpm, 8:07 PM 2/18/2002]
Old Feb 18, 2002 | 07:31 PM
G's Avatar
G
Default Re: is there a reason for this..(oil gauge related). (quikrpm)
Loops can be good, but if the tubing is 1/8", you may have differing oil pressures, lower to be exact. One loop is fine, but the Tee for the senders and oil line fitting has to be bolted to the block (in case it wasn't already). HTH
I wish I had my own mechanic....
[Modified by G, 8:32 PM 2/18/2002]
Old Feb 19, 2002 | 09:16 AM
WOTTEG's Avatar
Are you using the 1/8" nylon line from the block to the "T"?
You can do all of this yourself.
The only reason the loop is there is to give slack between the "T" and the block. As long as there is slack you are OK, but this does seem excessive.
Make sure when you cut the 1/8" nylon tubing that you sand down the end with very fine sand paper to ensure it is perfectly square (90 degrees). This will prevent any leaks.
thatcivic96
Jan 20, 2013 12:20 PM
alex1320
Dec 18, 2012 04:57 PM
redflaredcrx90
Oct 11, 2008 10:41 PM
mc
May 14, 2006 05:08 AM
BoostedSi
12
Jan 15, 2002 07:35 AM
