vaccuum leak...
Old Jul 25, 2005 | 12:04 PM
PnoyJeff's Avatar
Default vaccuum leak...
how do u find the vacuum leak/where do u look when u know u have one.....idle surging
Old Jul 25, 2005 | 01:49 PM
JimBlake's Avatar
Default Re: vaccuum leak... (PnoyJeff)
Listen for a whistling noise as air is sucking into the leak. Common places you can check are...
throttle shaft
throttlebody gasket
injector seals where they stick into the manifold
manifold gasket against head
gaskets where IACV mounts to manifold
brake booster
ANY of those zillion little vacuum hoses...
since it's a gsr, you also have...
secondary butterfly (IAB) shaft
gasket where intake manifold comes apart near IAB butterflys
phong3992
Aug 25, 2010 09:54 PM
AllmotorGSReg
Nov 19, 2009 12:12 PM
emooheo
Aug 19, 2007 03:10 PM
Shizznaz
Sep 2, 2005 08:07 AM
dc2turbo
Dec 13, 2004 05:33 PM
