accesory additional obd1 switch
I tried searching under a bunch of different things but no luck. I was wondering if anybody knew of a factory-like switch like the sunroof or foglights one and where to find it. I wanted to make a switch to check my obd1 codes and wanted to put it in one of the slots and make it look as factory as possible.
ED rear window defogger switch from the junkyard would work.
Two pins have continuity when the switch is closed, no continuity when opened.
One wire from the ecu to the switch and another wire from the swictch to ground and the mil indicator will illuminate.
Modified by eda6 at 6:14 PM 7/25/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatchsi »</TD></TR><TR><TD CLASS="quote">just get a toggle switch and hide it somewhere. no need for a big *** switch just to pull codes</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy »</TD></TR><TR><TD CLASS="quote">
If i didnt zoom in you wouldnt be complainin
Hook me up yo!
</TD></TR></TABLE>Hook me up yo!
SR20 Inside
Jan 25, 2006 09:24 PM
