no start problem
Last month, I got into an accident resulting in front end damage to my Civic. Now that its all back together again, I try and start the car but it only cranks. Ive had some buddies come by to help figure it out and im thinking that we have the problem narrowed down...or at least we did.
When the hood bent from the accident it put a little crack on the distributor cap and distributor itself.
Fuses are good, battery is good but we have no spark.
And I just changed the plug wires, plugs and cap.
Let me know what you guys think. Like I said, Im pretty sure we've pinpointed the problem but just want to hear honda-tech's opinion.
Modified by 13BT at 3:35 PM 7/25/2005
Have you tried jump starting it and if it starts its your alternator if you jump start and it wont start probably starter duh and if all falls replace the whole distributor. Oh yeah one thing did you check the battery.
problem solved!!!! turns out that it was my distributor. last night my buddy came over and swapped his dist. onto mine and my car fired right up!! time to hit up eBay!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13BT »</TD></TR><TR><TD CLASS="quote">problem solved!!!! turns out that it was my distributor. last night my buddy came over and swapped his dist. onto mine and my car fired right up!! time to hit up eBay!!! </TD></TR></TABLE>
It's probably just the coil inside the distributor, but you might as well buy a complete distributor from Distributor King. I personally run one in my 90 HB, and it's been great thus far.
A new coil from Honda costs $90.00 - you could easily put that towards a complete dist. From Distributor King.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
A new coil from Honda costs $90.00 - you could easily put that towards a complete dist. From Distributor King.</TD></TR></TABLE>
Exactly, just buy a new one and you'll be golden.
fortyfacemohwhat
Oct 17, 2008 05:40 PM
