Buddy club Spec 3+ valve lash
Old Jul 25, 2005 | 07:31 AM
ultimatehonda's Avatar
Default Buddy club Spec 3+ valve lash
Ok I just installed a set of buddy club 3+ cams with buddy club cam gears and omni power springs and retainers. I am having some noise from the valve train. I need to know whats the correct valve lash. I adjusted them to .008intake and .009exhaust. Is this correct for this set up or should I have done the .007in .008ex.? Thanks
Old Jul 25, 2005 | 11:26 AM
Default Re: Buddy club Spec 3+ valve lash (ultimatehonda)
Anyone??
Old Jul 25, 2005 | 01:54 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
No offense, but couldn't you just call BuddyClub? Or an authorized dealer?
Old Jul 25, 2005 | 02:22 PM
ninor's Avatar
you are fine on lash, how are your LMAs?
Old Jul 25, 2005 | 02:53 PM
Default Re: (ninor)
The lMA's are good. The motor has only 66k on it. Nothing was abnormaly worn. I have tried to contact a dealer but everyone gives me different specs. I think im going to try the stock specs. I read today in older posts thats some people are running the stock specs...
Old Jul 25, 2005 | 06:12 PM
an2ny888's Avatar
Default Re: (ultimatehonda)
buddy club reccomends 8 and 9 , so that's what i used, but like you i'm also experiencing some noise
Old Jul 25, 2005 | 06:54 PM
Default Re: (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">buddy club reccomends 8 and 9 , so that's what i used, but like you i'm also experiencing some noise</TD></TR></TABLE>
Are you experiencing a loss of power or bogging?
Old Jul 25, 2005 | 09:40 PM
an2ny888's Avatar
yeah i did experience that. car feels good initially but then sometimes it boggs after i've driven for a while. hasn't happened lately though
Old Jul 26, 2005 | 04:20 PM
Just redid the valve adjustment. I set the intake to .007 and the exhaust to .008
No more ticking and feels better too, but now needs to get tuned.
Old Jul 26, 2005 | 05:15 PM
Hybrid96EK's Avatar
Not the specs i've seen given with the spec iv's.. .007 and .008.
Old Aug 2, 2005 | 06:05 AM
fracas's Avatar
I just installed these same cams in my B16a2 head. I set the Valve's at .008 intake and .009 exhaust. Had no problems.
Old Aug 2, 2005 | 02:33 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Not the specs i've seen given with the spec iv's.. .007 and .008.</TD></TR></TABLE>
correct, same for Spec III and spec III+. Stock Valve lash
BTW- ive sold 4-5 sets of Buddy Club Cams and all the spec sheets say the same
edit- and so do skunks... ..007 and .008
Old Aug 2, 2005 | 05:07 PM
Hybrid96EK's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">
edit- and so do skunks... ..007 and .008 </TD></TR></TABLE>
Yeah. I realize now that its different for the spec 4's and 3+'s... sorry.
Old Aug 2, 2005 | 05:24 PM
GUILOTINE's Avatar
Kill Gil
Yeah. I realize now that its different for the spec 4's and 3+'s... sorry.</TD></TR></TABLE>
nope they are the same .007 and .008
Old Aug 2, 2005 | 05:45 PM
an2ny888's Avatar
their website specifies 8 and 9 for the bc3+, didn't look at the bc4
Old Aug 2, 2005 | 05:59 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">their website specifies 8 and 9 for the bc3+, didn't look at the bc4 </TD></TR></TABLE>
nope, must be a type-o .008 and .009 will cause loud valve slap at idle
Old Sep 18, 2005 | 10:43 AM
dwnthehatch's Avatar
I just installed my III+ cams and are pretty noisy. I set the lash at .008 and .009 per Buddyclub USA's instructions. Can anyone verify that this is a typo? There aren't even cams listed on the Buddyclub.jp website.
Old Sep 18, 2005 | 03:40 PM
ninor's Avatar
I run my bc3+ @ 7 and 8. no problems
Old Sep 18, 2005 | 05:41 PM
sander's Avatar
2.7(p/t)
Default Re: (dwnthehatch)
Loud valves arent as bad as people think, its better to have them too loud then too quiet.
You cant hear a tight valve. And tight valves are way worse than loose valves.
-s
Old Sep 18, 2005 | 06:10 PM
Hybrid96EK's Avatar
Default Re: (sander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander &raquo;</TD></TR><TR><TD CLASS="quote">Loud valves arent as bad as people think, its better to have them too loud then too quiet.
-s</TD></TR></TABLE>
Incorrect. Tight valves will lead to burnt valves as well as poor performance. Poor performance isn't as much of a deal as burnt valves, for sure. Loose valves however will result in rapid increase of wear on valvetrain components. As you can see, too tight and too loose both have rather harsh effects on engine life.
Old Sep 18, 2005 | 06:23 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">nope, must be a type-o .008 and .009 will cause loud valve slap at idle</TD></TR></TABLE>
The sheet that came with my BC3+ says .008 and .009... I'm probably going to adjust them to the loose side of .007 and .008 anyway, I've heard a lot of people having more luck with that.
Old Sep 19, 2005 | 02:49 AM
an2ny888's Avatar
Default Re: (drdisco69)
i would think buddy club knew what they were doing when they specified 8 and 9 valve lash for their cam, after all they did design it
Old Sep 19, 2005 | 08:18 AM
drdisco69's Avatar
You would think so, huh? Seems like some people using .008 and .009 have idle troubles, bogging, etc. It's just a valve adjustment, and takes all of 15 minutes to change if it's not working how it should. Besides, I need that extra .001" of lift!
Old Sep 19, 2005 | 08:22 AM
sander's Avatar
2.7(p/t)
Incorrect. Tight valves will lead to burnt valves as well as poor performance. Poor performance isn't as much of a deal as burnt valves, for sure. Loose valves however will result in rapid increase of wear on valvetrain components. As you can see, too tight and too loose both have rather harsh effects on engine life.</TD></TR></TABLE>
Read what i said.
I said tight valves are quiet, its better to have valves a little looser and louder than a little too tight. the longer the ex valve can contact the head the better chance it has of cooling down by dispersing the heat back in to the head. The amount of wear that .001 greater lash will put on valve train is so insignfigant i would much rather have my valve lash set looser than tighter than to have risk of burning valve.
-s
Old Sep 19, 2005 | 10:27 AM
I just got off the phone with Buddyclub USA which said .008 and .009.
BUT... he said ".007 and .008 also work, sometimes you have to play with them to get the best results" I'll stick with the looser settings.
trecool44
Mar 25, 2014 07:47 AM
all-mtr-teg
Jan 6, 2007 09:57 PM
turbotime
Oct 9, 2005 08:50 AM
DAmn
Sep 12, 2005 11:32 PM
slipstreamsi
Jun 2, 2004 12:14 PM
