LS B18B1 Cam Gear
Old Jul 24, 2005 | 09:58 PM
BlackDC4's Avatar
Default LS B18B1 Cam Gear
I Got a 94 LS."USDM" and i put crower stage 2 cams in it, i asked the guy at the "tuner" shop if i needed gears, he said the only time i'd notice them is if i put it on a dyno. today my friend said that i need them to pull my car through the rpm's until redline......what should i do? plus i'm seeking boost in the future(and springs&retainers)
Old Jul 26, 2005 | 11:23 PM
BlackDC4's Avatar
Default Re: LS B18B1 Cam Gear (0Q0Q0Q0)
no seriously, i want someones advice on this......couldnt find n e thing in particular.....i searched.no such luck n e suggestions would be good.thanks
Old Jul 26, 2005 | 11:29 PM
BlackDC4's Avatar
Default Re: LS B18B1 Cam Gear (Palmy Blue)
thanks man, i was wondering if it was worth the hassle.any suggestions on springs and retainers? what brand...i want boost, so i need them for the cams.plus i'm going for a ECU with no rev limiter, prolly not smart for an LS(from what i've been told) but i need springs for sure....
Old Jul 26, 2005 | 11:36 PM
xdc2b18c1x's Avatar
r u running stage 2 cams with stock retainers and springs? I thought it was required to change them with the stage 2's.
Old Jul 26, 2005 | 11:41 PM
BlackDC4's Avatar
Default Re: LS B18B1 Cam Gear (xdc2b18c1x)
yea, stock internals. all i have inside is the cams and a new cam seal. external is short ram intake,skunk2 manifold,plug wires and greddy evo2 cat.
Old Jul 26, 2005 | 11:46 PM
xdc2b18c1x's Avatar
you might as well get cam gears because you will have to tune since you did get cams. i have stage 1's on mine and im still waiting to install my skunk2 cam gears.
Old Jul 27, 2005 | 12:59 AM
98BlackTeg's Avatar
What stage 2? 6402T's or 62403's? As for springs, it is suggested to upgrade.
Old Jul 27, 2005 | 07:56 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: LS B18B1 Cam Gear (98BlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">What stage 2? 6402T's or 62403's? As for springs, it is suggested to upgrade.</TD></TR></TABLE>
Yeah? What is "Stage 2"? Crower doesn't work in "stages", at least they didn't several years ago when I got mine. The 402T's don't require their spring/retainers, but the 403's do. I didn't run aftermarket springs/retainers when I used their 402T's.
Old Jul 28, 2005 | 09:33 PM
BlackDC4's Avatar
Default Re: LS B18B1 Cam Gear (shamoo)
stage 2 turbo cams 62402t-2, i checked the crowers website and it says springs and retainers are required...i'm doing those before i boost it but a guy has a ECU with no rev limiter and more fuel. i dont know if its chipped or what but its only 90 bucks so i figured get it.but my motor has 156k and its my only car...no sure if its a good thing for me
y2kferari
13
Feb 18, 2009 12:54 PM
yoRt
57
Jan 28, 2009 08:30 PM
My JDM EJ8
Dec 21, 2008 06:08 AM
h22vt
Jan 26, 2006 03:15 PM
Civicse
13
Feb 22, 2005 12:26 PM
