ITR CAM vs CTR CAM Which is better for ls vtec build?
Old Jul 24, 2005 | 07:32 PM
Vtecme92's Avatar
Default ITR CAM vs CTR CAM Which is better for ls vtec build?
Ok guys I am building up a LS vtec setup and here is the setup so far engine wise:
B18b block
CTR piston
with a
GSR head
GSr tranny
my debating right now is should I get Integra tpye R intake & Exhuast cam or Civic Tpye R cams? Are they are the same in providing horse power or is one better than the other..my ultimate goal is the run low 13's maybe high 12’s all motor in my hatch still have a long way to go with my setup but buying one item at a time...any input would be helpful..
Old Jul 24, 2005 | 08:17 PM
MUGEN_CF4's Avatar
Default Re: ITR CAM vs CTR CAM Which is better for ls vtec build? (Vtecme92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys I am building up a LS vtec setup and here is the setup so far engine wise:
B18b block
CTR piston
with a
GSR head
GSr tranny
my debating right now is should I get Integra type R intake & Exhaust cam or Civic Type R cams? Are they are the same in providing horse power or is one better than the other..my ultimate goal is the run low 13's maybe high 12’s all motor in my hatch still have a long way to go with my setup but buying one item at a time...any input would be helpful..
the difference between ITR and CTR cams is so negligible, u wouldn't be able to tell the difference between equal drivers using either cams in the same setup.
since you're going with CTR pistons, why don't u go with a cam with more duration than type r? u'r going to need to bleed off that cylinder pressure to avoid blowing it up.
Cyrus4g63
Aug 31, 2006 08:26 PM
gilou bilou
Oct 2, 2005 11:58 AM
ReV LiMiT
32
Oct 13, 2004 03:16 PM
speeddave
May 3, 2002 10:32 AM
