removing A/C components = much better radiator cooling? ..
Old Jul 24, 2005 | 04:00 PM
AccordRacing's Avatar
Default removing A/C components = much better radiator cooling? ..
If you remove A/C, (most notably the radiator looking unit in front of the radiator), you will get muuuuuuuuch better air flow to the radiator and in turn much more efficient cooling system? ..
.. would it be possible to get a smaller aftermarket one and relocate the unit?
Old Jul 24, 2005 | 04:27 PM
KOALA YUMMIES's Avatar
Default Re: removing A/C components = much better radiator cooling? .. (AccordRacing)
Are you having over-heating problems, because if you are ditching the A/C system to provide more airflow to band-aid the problem would be the first I've heard of it (and a stupid reason to as well IMO).
BTW the "radiator looking unit" is called a condenser.
Old Jul 24, 2005 | 05:22 PM
wpsadmin's Avatar
Default Re: removing A/C components = much better radiator cooling? .. (KOALA YUMMIES)
i don't know what am i gonna do without AC
Old Jul 24, 2005 | 05:27 PM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordRacing &raquo;</TD></TR><TR><TD CLASS="quote">If you remove A/C, (most notably the radiator looking unit in front of the radiator), you will get muuuuuuuuch better air flow to the radiator and in turn much more efficient cooling system? ..
.. would it be possible to get a smaller aftermarket one and relocate the unit?</TD></TR></TABLE>
If your car is a track car and you're after saving weight, go ahead.
If your car is overheating, what you're talking about isn't the solution. Most of us have no cooling problems at all pushing the air through the condensor and dissipator, assuming that there are no leaks or air locks, both fans are coming on as required, and that the system is just working the way it should.
Do you mind if I ask why you're thinking about this?
Old Jul 25, 2005 | 06:44 AM
deserthonda's Avatar
if it is for racing purpose remove all the a/c components, compress, eval lines etc etc if it is for overheating purpose like GEORGE says you got a problem with cooling system
GBRacing
Aug 8, 2005 05:41 AM
tkHBseries
Feb 19, 2005 06:48 PM
Superhatch
24
Sep 20, 2004 10:13 AM
FrostyDC4
Aug 29, 2004 05:04 PM
EGh22aEG
Jan 9, 2002 06:37 PM
