Max bore for LS block.
Old Jul 24, 2005 | 03:58 PM
DC-4-Drew's Avatar
Default Max bore for b18 block.
To make a long story short, I after only about 1000 miles on my LSvtec build, I have a cracked piston and the walls are a little scar'd up. What is the max bore I can go without sleaving my b18 block? Thanks.
Old Jul 24, 2005 | 04:23 PM
N_A_is_best's Avatar
Default Re: Max bore for b18 block. (LSvtec delsol)
82mm
Old Jul 24, 2005 | 06:30 PM
civdx94's Avatar
Default Re: Max bore for b18 block. (N_A_is_best)
you can get 82mm jdm ITR replicas from spark racing for 150 with rings shipped. i would much rather use Safety brand pistons over top line if your considering them just thought i would give you an option
Old Jul 25, 2005 | 03:02 PM
BluePrintmfg.com's Avatar
Banned
Default Re: Max bore for b18 block. (civdx94)
depending on the damage to the walls of you block 82mm would be the max bore
Old Jul 25, 2005 | 05:28 PM
DC-4-Drew's Avatar
Default Re: Max bore for b18 block. (11sec.ALL MOTOR)
I used topline before and they were busted after 1000 miles. I can't absolutely say they were the culprit, however the rings and bearings were intact. I don't think I will use them again. Thanks guys.
Old Jul 25, 2005 | 05:31 PM
sheepey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civdx94 &raquo;</TD></TR><TR><TD CLASS="quote">you can get 82mm jdm ITR replicas from spark racing for 150 with rings shipped. i would much rather use Safety brand pistons over top line if your considering them just thought i would give you an option</TD></TR></TABLE>
Safety I miss working for them . Great company thats for sure
cherryredcivic
Nov 22, 2011 06:13 AM
diouf
Sep 30, 2011 08:07 PM
BigPlansNoMoney
Feb 24, 2008 08:01 AM
KingOfQB
10
Mar 4, 2006 07:30 AM
untitled
Jul 19, 2003 03:18 PM
