b16 turbo throwing CEL 5??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edge099 »</TD></TR><TR><TD CLASS="quote">Get a 3 bar map sensor for like $90 bucks</TD></TR></TABLE>
no need i will only be running 10psi thats overkill, im using a BLOX type b missing link. its working fine now. it was installed backwards. I totally dont understand how this thing works but it does work. it will not allow air to flow to the MAP sensor from the vacuum source but it allows air flow coming from the MAP sensor. freaking weird, the MAP can actually produce vacuum on its own or at least create some kinda pressure to measure the amount of positive pressure against it??????
