sunroof wont close "93 civic
Old Jul 24, 2005 | 02:12 PM
DjN3M3S1S's Avatar
Default sunroof wont close "93 civic
alright so it started to rain the other day when it was open. so i started to close it but it didnt close all the day, so i tried pulling it.
now its the even, so i took off the glass, and noticed that the driver side works fine, but the other side stop halfway.
i sprayed some wd40 and tried pushing it back in so it will at least close, but no luck.
i ended up having to close it manually, but the back side it still popped up..
any ideas?
Old Jul 25, 2005 | 05:25 AM
DjN3M3S1S's Avatar
Default Re: sunroof wont close "93 civic (DjN3M3S1S)
bump
Old Jul 25, 2005 | 05:37 AM
ralphie14's Avatar
If you keep turning the manual screw I am prety sure the back will close as I am pretty sure that mine did when I had to do it manually once. I have a 93 Hatch and mine is giving me **** too mine will open fine but when it comes time to close it seems that something is wrong with the motor and I have to pull it along. Sounds a little different than your issue but I just plan on replacing the motor at some point.
Old Jul 25, 2005 | 05:42 AM
JDM-EJ1's Avatar
Default Re: sunroof wont close "93 civic (ralphie14)
It's most likely the motor, mine runs a bit slugish too. Espically when I'm the freeway, I guess the wind going against it makes it go slower than normal.
Old Jul 25, 2005 | 03:26 PM
Eg6xCiViCxSi's Avatar
mines doing the same thing and i cant figure out how to close i too would like too know
Old Jul 25, 2005 | 03:30 PM
96CivicBoostCoupe's Avatar
Default Re: sunroof wont close "93 civic (Eg6xCiViCxSi)
lithium white lube the **** out of the tracks and adjust it and it should be fine
jdmNit
Mar 3, 2011 07:25 PM
BLUCIVICSl2
May 8, 2009 02:11 PM
r3sgtec
Feb 23, 2009 12:55 PM
honda25
Feb 7, 2003 06:01 AM
