B20 Intake Manifold on LS Head????
The intake manifold and exhaust manifolds all swap between all b series motors. the problem with the b20 intake manifold is that it is too tall to fit under the hood of your car. you'd either have to get a new hood with a hole in it to get it to fit properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3dda6pn0y »</TD></TR><TR><TD CLASS="quote">The intake manifold and exhaust manifolds all swap between all b series motors. the problem with the b20 intake manifold is that it is too tall to fit under the hood of your car. you'd either have to get a new hood with a hole in it to get it to fit properly. </TD></TR></TABLE>
the manifold is a lot taller than the b18 mani. just looking at you would be able to tell that it wouldn't fit. why don't you just use the b18 mani?
i need a final answer. fully built head is going on this weekend and need to know if i can go ahead and switch over intake manifolds without a problem. bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg »</TD></TR><TR><TD CLASS="quote">
the manifold is a lot taller than the b18 mani. just looking at you would be able to tell that it wouldn't fit. </TD></TR></TABLE>
theres your answere.
i bought it really cheap from this guy. he said he had too many parts just laying around. got it for 100 dollars. hella cheap
Modified by jdmteg96 at 3:35 PM 10/10/2005
a ITR IM would need to be modified to fit a P72 head
The b20 IM, IS TALL AS HELL. I however, am not taking the manifold off mine. I am thinking I will cut a hole in my hood, and have a 1 foot pipe coming off the throttle body straight into the air with a filter on it. Or maybe I will make some kind of scoop to cover it. Dont change it my friend, embrace the fact that it is up higher, put it in the cold air. Hah.
not a good 1st post, dog. b16/itr intake manifold bolt patterns are different from the gsr, which is different than the ls.
irideslammed5021
Jun 9, 2007 07:46 AM
mingchi69
Sep 5, 2003 07:43 PM
Spade
May 20, 2002 06:55 AM
Charlie Moua
May 16, 2002 08:54 PM
