only two cylinders are working in my 92 integra LS
Old Jul 24, 2005 | 06:24 AM
wacktical's Avatar
Default only two cylinders are working in my 92 integra LS
i rebuilt my LS motor (sleeved, bigger pistons, stronger rods etc.) i installed the engine and only two cylinders are working. what could be the problem?
Old Jul 24, 2005 | 07:50 AM
IN VTEC's Avatar
Default Re: only two cylinders are working in my 92 integra LS (wacktical)
Inverted a pair of spark plug wires?
Old Jul 24, 2005 | 07:58 AM
wacktical's Avatar
Default Re: only two cylinders are working in my 92 integra LS (IN VTEC)
already checked that...
maybe this would help...
when i sprayed brake fluid up the intake it runs fine ..so im thinking its not getting any fuel.
does the vafc have anything to do with the problem...any settings i need to put it on?
Old Jul 24, 2005 | 08:04 AM
IN VTEC's Avatar
You have to set the type to 4 CYL and the TPS voltage input as rising upward.
Old Jul 24, 2005 | 08:18 AM
wacktical's Avatar
could me not hookin up the intercooler piping be a problem because im missing alittle piece of pipe so that part is just open right now...just a little note.
Old Jul 24, 2005 | 10:14 AM
apok's Avatar
No, that would only matter in cars with a MAF sensor. Those cars would sputter and die. Your car possesses none, therefore if the turbo piping ever blew, you'd just run like an NA car.
Make sure your spark plug wires are firing, your timing is on, and that your injectors and fuel pump are working.
Old Jul 24, 2005 | 10:21 AM
wacktical's Avatar
okay the spark plugs are firing....
the timing is good....
the injectors are good cause i flip flopped it with the the 1,4, and still one and four is not working...
the fuel pump...haven't checked that yet but, if the 2,3 cyclinders are good, then that means that the pump should be good right?
Ls_eg6
Aug 4, 2008 03:14 PM
thisboyjulio
Jul 7, 2008 11:42 PM
Cyphear
Aug 4, 2007 10:18 AM
All Motor EH2
Mar 4, 2005 05:55 PM
NatedoggAZ
May 19, 2004 01:37 PM
