Flywheel & Pressure Plate Question
Ok just got a new set of Clutch and Flywheel for my current build. I got a Toda Flywheel and Toda Clutch.
Now factory honda b-series engines use 6 pressure plate bolts even if the pressure plate has more holes due to the fact that the flywheel has only 6 pressure plate threaded holes.
Now my Toda flywheel has all 9 pressure plate threaded holes that match with all the holes on the clutch pressure plate. Now do I just use the factory 6 pressure plate bolts only or due I need to get 3 more and use all 9.
Johnmadsen
Feb 11, 2019 07:19 AM
