**Do I have to remove the driver's side front wheel for tranny fluid change?
Old Jul 23, 2005 | 11:04 PM
CaliAgents1688's Avatar
Default **Do I have to remove the driver's side front wheel for tranny fluid change?
I'll be following these directions from i-vtec daily:
http://ivtecdaily.com/rsx/mods/drainBolts.html
kinda odd that you'd have to remove a wheel for a tranny fluid swap. Anything else I should look out for?
Old Jul 24, 2005 | 12:13 AM
The Bagel's Avatar
Default Re: **Do I have to remove the driver's side front wheel for tranny fluid change? (CaliAgents1688)
I replaced my MTF with redline synthetic at 15K, but I had a lift. One thing I can suggest is taking an old grease gun and cut the end off the hose. Fill it with fluid, and pump it into the tranny. Screw the long funnel, that's a PITA
Old Jul 24, 2005 | 12:35 AM
Default Re: **Do I have to remove the driver's side front wheel for tranny fluid change? (Day_Old_Bagel)
yeah, no doubt... I have a STA-LUBE pump which should be perfect. But do I need to remove the front wheel?
Old Jul 24, 2005 | 05:30 AM
kung fu grip's Avatar
no. just pop you 3/8" socket wrench directly into the fill/level plug and remove it.
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
silver_nteg
Mar 27, 2004 09:44 PM
Seedc2
Aug 6, 2003 05:59 PM
sutrusu
Jun 25, 2002 01:20 PM
hb_racer
Mar 17, 2002 06:27 PM
