car has fuel and spark but doesnt start. please help!
Old Jul 23, 2005 | 08:35 PM
DC2point0's Avatar
Default car has fuel and spark but doesnt start. please help!
hi everyone.
a buddy and i have just swapped a D16z6 into my car. the swap is basically complete. all the wiring is pluged in. the car has fuel. car has spark. i dont know about the timing. cause we bought the whole swap and swappped it in.. the original owner didnt open up the motor. he said the car was running before he pulled the motor out.
so the car cranks but doesnt not start.. sometimes it sounds like it wants to start but doesnt start. i tried spraying starter fluid into the TB but still doesnt work.
Another thing, my buddy added gas to the car from a gas can that was in his backyard. i tried to start the car it wont start. then it turns out the gas was a mix of gas and oil that his dad mixed for his lawn mower and stuff like that. So once i realized that, i drained all the bad gas out of the gas tank. put premium gas in there (92 octane) and disconnected the gas like from the fuel rail and turn the key on so the fuel pump would push all the bad gas our with the new gas. then i also put new injectors on there cause the other one was contaminated with the shitty mix of gas and oil. then i also took the spark plugs out and cleaned them up. then i also put some rubbing alcohol in the cylinder so it will evaporate all the shitty gas mix that got inside the cylinder. so now the engine gets good gas all the way through. i still dont know why it wont start. sometimes it sounds like it wants to start. but doesnt.
if you have any idea whats wrong or any suggestions. please speak up. any help is appreciated. thanx
Old Jul 23, 2005 | 09:04 PM
Backk InTheDA's Avatar
I hate everything
Default Re: car has fuel and spark but doesnt start. please help! (DC2point0)
Maybe your dizzy? When you say it "tries" to start, does it just hesistate then quit?
I'll bump this, because im interested as well.
Old Jul 23, 2005 | 09:11 PM
DC2point0's Avatar
Default Re: car has fuel and spark but doesnt start. please help! (BuilttB18C5)
it tries to start as in.. crank crank then flooooop floooooop like it about to start. and some smoke would come out of the exhaust.
its not the distrubutor, it came from my old motor. it was running just fine.
Old Jul 23, 2005 | 10:00 PM
transpar_nt's Avatar
check the fuel filter. If some oil started passing through your lines it would get clogged fast.
Old Jul 23, 2005 | 10:11 PM
I hate everything
Default Re: car has fuel and spark but doesnt start. please help! (transpar_nt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">check the fuel filter. If some oil started passing through your lines it would get clogged fast.</TD></TR></TABLE>
Thats true. Might suggest pulling an injector, to see what it looks like, just because of that oil.
best of luck man.
Just a quick question, why swap another z6? Just need a car that runs?
Old Jul 23, 2005 | 10:18 PM
crxog's Avatar
yea
Old Jul 23, 2005 | 10:31 PM
WCI's Avatar
WCI
check the map and TPs plugs. Make sure they are not switched. Check all no brainers first. That seems to be where I always make my mistakes.
Old Jul 23, 2005 | 10:41 PM
EGmikeH22's Avatar
* B A N N E D *
look for CELs and if you don't have any make sure the wire are on the right places on the dizzy. top left is 3 then clockwise goes 3421
Old Jul 23, 2005 | 10:58 PM
DC2point0's Avatar
Default Re: (EGmikeH22)
We replaced the injectors and fuel regulator, the firing order is correct, and the map and tps sensors should be right since the harness was never removed..but we have a fuel filter off a b17 that we will try tomorrow.
Old Jul 24, 2005 | 02:43 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (DC2point0)
i say check the timing.
Old Jul 24, 2005 | 03:58 AM
JDM-EJ1's Avatar
I'm saying timing or injectors.
Old Jul 24, 2005 | 01:36 PM
DC2point0's Avatar
Default Re: (JDM-EJ1)
I just checked timing and its fine, injectors are replaced, about to replace the fuel filter and the 02 sensor..
Old Jul 24, 2005 | 03:48 PM
DC2point0's Avatar
k just another update.. new ECU. new O2 sensor. car still dont start.
Old Jul 24, 2005 | 06:02 PM
96CivicBoostCoupe's Avatar
that sounds like a timing issue to me, try removin the dizzy and spin the shaft 180 put it back in and see what happens, i had that problem, #1 cyle=inder was at tdc and it was tryin to fire cylinder#3
dan89crxsi
16
Sep 24, 2006 01:22 PM
LvN
Jun 9, 2006 11:31 AM
DA6_toojy
Oct 12, 2005 06:30 PM
Sergei01
Apr 12, 2004 11:30 PM
garagespecial
Jun 25, 2002 10:00 AM
