Question about the B16B engine.
Old Jul 23, 2005 | 06:13 PM
JDM_B16_EG6's Avatar
Default Question about the B16B engine.
I just want to know the main differences between the B16B engine from the Civic Type R and the B16A from the Civic Si or any EG6.
I know that the camshafts are different, the crank pulley and so many other parts.
There is any difference in the crankshaft? and/or the rods?
Old Jul 23, 2005 | 06:47 PM
RagingAngel's Avatar
Default Re: Question about the B16B engine. (JDM_B16_EG6)
SEARCH........
Your search for B16B returned 62 results. (archived all motor forum)
Your search for B16B returned 24 results. (recent all motor forum)
Old Jul 23, 2005 | 06:53 PM
sheepey's Avatar
deck height,intake manifold, i dunno bout the TB, valvetrain.
Old Jul 23, 2005 | 06:56 PM
93hatchin's Avatar
its a destroked b18c5
Old Jul 23, 2005 | 07:08 PM
Yambor's Avatar
Default Re: (93hatchin)
pistons are different too!
Old Jul 24, 2005 | 05:03 AM
DEMNTD1's Avatar
Default Re: (JH4DC4-2GSR)
Head is factory polished (slightly), larger IM, larger TB, more agressive cams, block girdle, higher compression pistons, block deck height is the same as B18, dual valve springs on INT/EXH, factory red valve cover, ecu higher redline,.....
Old Jul 24, 2005 | 06:14 AM
Pondus's Avatar
Default Re: (DEMNTD1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEMNTD1 &raquo;</TD></TR><TR><TD CLASS="quote">Head is factory polished (slightly), larger IM, larger TB, more agressive cams, block girdle, higher compression pistons, block deck height is the same as B18, dual valve springs on INT/EXH, factory red valve cover, ecu higher redline,..... </TD></TR></TABLE>
As already mentioned it's basically a destroked B18C.
Old Jul 27, 2005 | 06:34 PM
93hatchin's Avatar
to add to that its got a bit more aggressive charateristics than the older type r engine. OT can you BAR a b16b engine in cali?
Old Jul 27, 2005 | 07:18 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatchin &raquo;</TD></TR><TR><TD CLASS="quote">to add to that its got a bit more aggressive charateristics than the older type r engine. OT can you BAR a b16b engine in cali?</TD></TR></TABLE>
Was the engine ever offered stock in U.S. automobile?
Old Jul 27, 2005 | 07:20 PM
93hatchin's Avatar
nope. not the b16b.
Old Jul 27, 2005 | 07:39 PM
Then no, i dont believe its LEGALLY smogable.
LEGALLY being the key word.
Old Jul 27, 2005 | 08:02 PM
xEnderx's Avatar
Default Re: (LsVtec92Hatch)
The differences are massive. Do a search and you will find a plethora of info on it.
As a 16B owner I'll vouch for it any day. WOnderful motor.
Old Jul 27, 2005 | 08:20 PM
93hatchin's Avatar
got ya *wink*
Old Jul 27, 2005 | 08:22 PM
Hybrid96EK's Avatar
Commonly made mistake. A Civic Type R TB is actually NOT 62mm and is a plain ole 60mm tb. Measured one myself straight from a B16B shipped from Japan. Make sure you measure the side by the throttle plate, NOT the opening, they taper.
Old Jul 28, 2005 | 06:37 AM
. o 69 o .'s Avatar
Default Re: (Hybrid93Eg)
best mod for a b16b engine is a LS crank. it makes some nice power
Old Jul 30, 2005 | 12:35 AM
turbohf's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">best mod for a b16b engine is a LS crank. it makes some nice power</TD></TR></TABLE>
then you would have a LS motor with beefy main girdle and a B16B head.... would have been easier to just buy an LS motor and ITR head....
Old Jul 30, 2005 | 05:29 AM
Grand's Avatar
Default Re: (turbohf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohf &raquo;</TD></TR><TR><TD CLASS="quote">
then you would have a LS motor with beefy main girdle and a B16B head.... would have been easier to just buy an LS motor and ITR head.... </TD></TR></TABLE>
exactly half the appeal of a b16b is its great rod to stroke ratio short stroke and high rpm power and stability an ls crank would ruin it youd have one expensive lsvtec
Old Jul 30, 2005 | 07:38 AM
Hybrid96EK's Avatar
Default Re: (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">
exactly half the appeal of a b16b is its great rod to stroke ratio short stroke and high rpm power and stability an ls crank would ruin it youd have one expensive lsvtec </TD></TR></TABLE>
I think that people are WAY too heavily into this whole Rod/Stroke ratio garbage. Sure, its nice, but only to a point. Such a high rod/stroke ratio just makes for one hell of a peaky engine. I guess if you like revving the **** out of something to get it going then its fine and dandy.
Old Jul 30, 2005 | 08:34 AM
Grand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
I think that people are WAY too heavily into this whole Rod/Stroke ratio garbage. Sure, its nice, but only to a point. Such a high rod/stroke ratio just makes for one hell of a peaky engine. I guess if you like revving the **** out of something to get it going then its fine and dandy. </TD></TR></TABLE>
i agree with you aswell id never own a b16b because i like a little bit of torque and its hard enough to get that even with 2.0; i was just saying that that is what alot of the appeal is of a b16b and that i would never buy a b16b motor and put in an ls crank because it would just be an expensive lsvtec that said 1.6 on the block
Old Jul 30, 2005 | 08:59 AM
turbohf's Avatar
hell never mind i think its a great idea!.....someone do it, and i will buy there B16B crank and rods
Old Jul 30, 2005 | 03:50 PM
. o 69 o .'s Avatar
clearly none of you have ever had a stroked b16b motor then
Old Jul 30, 2005 | 03:53 PM
Default Re: (B16B)
Sure i have, its called an LS/Vtec
Old Jul 30, 2005 | 06:14 PM
japspec's Avatar
Boy do we have some b16b haters. LOL
psegs80
Oct 16, 2009 05:48 PM
ggangtong81
Aug 21, 2005 10:17 PM
DONTNEED8
Mar 13, 2005 09:47 PM
JoeyBallzSI
Feb 9, 2004 05:03 PM
sporty240
16
Oct 17, 2003 06:34 PM
