push radio and off goes my radio and clock and now nothing help please
i have an aftermarket radio and the trim that goes around her was poping off so while the radio was playing i simply snapped it back on, snap and then bam nothing my jdm clock went out and the radio goes off with it, i was like humm thats wierd so i pop the radio out check the wires there fine and unplug her n replug her in. Nothing, turn the car off and try to press the plastic tab on the clock to turn her on. . . . . nothing also, click the key once and usually the clock n radio goes on but i get nothing. click to the second part when the battery light lights up and the click every so dimly lights up at 1:00 but its simply 8:30pm so the clock reset herself, shes so dim you can barely see it but when i press the tab she lights up a bright amber, when i let go dim again. Anyone have any idea wtf happened, checked the radio fuse n replaced it just incase but i got nothing please help me out thanks Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiPBoi »</TD></TR><TR><TD CLASS="quote">check all ur fuses....under ur hood..under ur steering wheel...u had to blow a fuse...</TD></TR></TABLE>Ditto that. it'd probably the 7.5A constant power, [back up] fuse in the engine bay fuse box.
94
94
bump ima try that, anyone else have an idea? theres no power to the radio and clock, power to the clock when the battery on the car is turned on, but not the first click with the key, when the clock goes on it says 1:00 every time and its very dim, i have to push the tab on the clock when the battery is on to see her light up
Modified by KiD Fr0m Da 516 at 2:12 PM 7/24/2005
Mecca8383
Nov 25, 2017 02:46 PM
KiD Fr0m Da 516
Jul 24, 2005 02:44 PM
