turbo manifold questions/
Old Jul 23, 2005 | 04:25 PM
KURUPTinc's Avatar
Default turbo manifold questions/
Quick question is there a gasket that goes inbetween the manifold and turbo plates? and i cant really tell wich port is the drain port for the oil on the turbo.
Old Jul 23, 2005 | 04:36 PM
Jizzmaster Zero's Avatar
(banned)
Default Re: turbo manifold questions/ (KURUPTinc)
You can get away without using a gasket if your surfaces are machined flat, which they should be.
What turbo is this? On my T3 the oil inlet is a small threaded hole, and the outlet (drain) is a bigger square opening.
Old Jul 23, 2005 | 04:44 PM
KURUPTinc's Avatar
Default Re: turbo manifold questions/ (Jizzmaster Zero)
yeah i got a t3 but the small hole isn't threaded. also on my wastegate can i have it just vent out into the atmosphere or might it be to hot to increase under hood temp?
Old Jul 23, 2005 | 06:06 PM
beepy's Avatar
You at least need a dump tube to route exhaust out. The exhaust will get into your vents and can kill you. Plus it will sound like a turbo lawnmower.
Old Jul 23, 2005 | 06:11 PM
KURUPTinc's Avatar
Default Re: turbo manifold questions/ (beepy)
ha nice
JKov240
Texas -OK -LA (Sales)
14
Aug 28, 2009 06:32 AM
lilintegra25
Jan 24, 2007 08:21 PM
projectPSI
Jul 20, 2004 08:54 PM
DLOTYPER
Jul 26, 2003 02:32 PM
GruvyTune
Dec 2, 2001 04:32 PM
