help losing power
Old Jul 23, 2005 | 04:25 PM
blitzrican22's Avatar
Default help losing power
i just did an obd1 on my 91 hatch with an 93 d16z6 when i run it it has power with the gas in about 1/4 of the way as soon as i push it down more it loses power and feel fast with a little gas then alot then if i full throttle it it cut off like the motor dies its weird help if anyone noes
Old Jul 23, 2005 | 08:21 PM
dr_latino999's Avatar
Default Re: help losing power (blitzrican22)
Did you do the conversion yourself or did you purchase a harness?
If you did purchase a harness, who was the manufacturor?
What ECU are you using?
If you are not using a P28 ECU, are you using a chipped ECU?
If you are running a chipped ECU, has it been properly set up and tuned with P28 maps?
Old Jul 25, 2005 | 08:03 PM
Default Re: help losing power (dr_latino999)
i did buy a harness and im using a stock p28 ecu, i bought it from rywire.com, it cant be the ecu because one day my boi let me use his ecu he has in his ex n it still did the same **** idnk man this **** is pissing me off help
Old Jul 25, 2005 | 08:13 PM
Is your timing set properly, i.e. with a timing light?
Old Jul 25, 2005 | 08:27 PM
jdmBluerex's Avatar
dam, that **** happens with my crx too. dont know why. it does it sometimes... well most of the time. it feels like it picks up faster when i push on the gas alittle then pushing the whole thing down...
Old Jul 25, 2005 | 08:29 PM
CaliforniaHighwayPatrol's Avatar
check your fuel filter, mine got clogged before
Old Jul 25, 2005 | 08:49 PM
PURPLETERROR aka BIGMATT's Avatar
Bad tps sensor, plugged fuel filter, bad fuel pump, or plugged cat.
$LiLPooky$
Engine Management and Tuning
Nov 19, 2009 04:01 AM
Razr2
10
Feb 14, 2008 06:16 PM
2000DC2_freak
Jan 31, 2007 04:55 PM
zenon8890
Nov 25, 2005 06:34 PM
JKim0901
Dec 25, 2001 11:48 AM
