Those with spoon calipers:
Wait a minute, aren't there bleed screws on the spoon clappers? From all my brake changes I've done when doing them I get a locking plier and lock it on the rubber portion of the brake line and open the bleed screw when pusing the piston back. That way you don't get any nasty fluid back into the line, hence the bleeding of course with the cap off and then just top off the resevior. I'm I doing something wrong or just being **** about it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PY0559 »</TD></TR><TR><TD CLASS="quote">Wait a minute, aren't there bleed screws on the spoon clappers? From all my brake changes I've done when doing them I get a locking plier and lock it on the rubber portion of the brake line and open the bleed screw when pusing the piston back. That way you don't get any nasty fluid back into the line, hence the bleeding of course with the cap off and then just top off the resevior. I'm I doing something wrong or just being **** about it?</TD></TR></TABLE>
.....totally unnecessary.
Thinking about this method puzzles me since if you're cutting off fluid coming into the caliper and you crack open the bleeder, isn't there a higher chance for air to be reintroduced into the system? That and using locking pliers on SS lines (for those who have it) is kind of pointless/useless.
Or am I over analyzing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">I used to use a pair of pliers and used the old pad to help push the pistons back. Then again, I'm just lazy like that.
Thats what I do. It works everytime.
</TD></TR></TABLE>Thats what I do. It works everytime.
Thanks for all the advice.
I just changed the pads this weekend and it was a cinch! Just loosen the bleeder screw a tad and pushed it in easily with my bare hands.
JDM PRO
22
Aug 30, 2005 04:51 PM
