Red Lining at 5600RPMs - why?
Old Jul 23, 2005 | 08:24 AM
turboME's Avatar
Default Red Lining at 5600RPMs - why?
My 95 Civic EX is redlining at 5600RPMs. Sometimes it will go clear to 7000RPM, but what is the problem? is it a VTECH computer error?
The only time i really started noticing this was after i forgot to put my sunroof up and it rained about 2inchs of water in my back floor. Would this have anything to do with messing up my computer?
Old Jul 23, 2005 | 08:34 AM
kabaroo's Avatar
Default Re: Red Lining at 5600RPMs - why? (turboME)
what do you mean by redlining at 5600? thats not possible, maybe for some odd reason you are hitting the rev limiter at 5600? unless you have a chipped ecu with a reduced rev limit or something i dont get it.
Old Jul 23, 2005 | 08:36 AM
kabaroo's Avatar
Default Re: Red Lining at 5600RPMs - why? (kabaroo)
if you know anyone with a civic 92-95 ex, si, or anyone with a stock p28 ecu you should try to swap ecu's to see if thats the problem. maybe some rain got on yours...
Old Jul 23, 2005 | 08:40 AM
turboME's Avatar
well, i dont know exactly how to say what it is doing. at 5500.. sometimes i can get 6000RPM, but what happens is it hits a limit around 5700RPM. I know it used to reach 6700RPMs before it would ever hit the limit point.
Ill have to look up where to get an ECU...
Old Jul 23, 2005 | 09:02 AM
skater5067's Avatar
mine does the exactly the same thing lol it like sounds like it is hitting the rev limiter but it doesent to it after i have been driving the car around for awhile
Old Jul 23, 2005 | 09:14 AM
fastrunner's Avatar
Default Re: Red Lining at 5600RPMs - why? (skater5067)
if the car is running weak then it could be in limp mode. any codes??? got oil?
Old Jul 23, 2005 | 09:57 AM
Calvinator's Avatar
Default Re: Red Lining at 5600RPMs - why? (fastrunner)
im voting limp mode.
Old Jul 23, 2005 | 10:16 AM
EK k kay's Avatar
Default Re: Red Lining at 5600RPMs - why? (xtremeazian)
If you were in limp mode you could definitely feel the power loss and and bogging.
Old Jul 23, 2005 | 10:18 AM
turboME's Avatar
Default Re: Red Lining at 5600RPMs - why? (my head a plode)
what is "limp mode"?
there are times when i floor it that i feel "spikes" of power that other times i usually dont feel. probably around 5000RPMs.
i dont know much about the whole VTECH thing, but is it possible that it isnt working. as in, when it is supposed to kick in (around 5700RPM) its actually not, and thats why its hitting the limit?
Old Jul 23, 2005 | 10:19 AM
kaiba's Avatar
Also could be your cluster going bad. When you redline at 5600 does it sound like it's 5600 or 6800(or wahtever ex redline).
Have ecu ever been chipped.
Old Jul 23, 2005 | 10:26 AM
turboME's Avatar
Default Re: Red Lining at 5600RPMs - why? (kaiba)
this car is pretty much stock. so i dont know if its been "chipped" before. i would bet not.
when i hit 5600, or 6000RPM is sounds like its about to blow, lol. i dont really feel anymore power after about 6000RPM even if it does go that far or further either. Although, when i first bought the car, before the rain soaked the back floor, it seemed to run stronger. probably not much, but noticable.
im going to go run it for a while and see if it will hit 7000RPM after warmed up.
the tach says the limit is like 7200RPM..by the way.
Old Jul 23, 2005 | 10:39 AM
Archidictus's Avatar
Unceasing Measure
Sounds like you're trying to redline it before the car's warmed up to me. And it's ******* VTEC, not "VTECH". Can you read? I mean, you can obviously spell so I would assume that you could read the four letter word on your valve cover, right?
Old Jul 23, 2005 | 10:44 AM
e jay one's Avatar
Default Re: Red Lining at 5600RPMs - why? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote"> I mean, you can obviously spell so I would assume that you could read the four letter word on your valve cover, right?</TD></TR></TABLE>
haha thats great. yea let it warm up and deffinatly try another ecu if you can. i dont think your tach would be off that much.
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboME &raquo;</TD></TR><TR><TD CLASS="quote">is it a VTECH computer error? </TD></TR></TABLE>
haha
Old Jul 23, 2005 | 12:31 PM
turboME's Avatar
Default Re: Red Lining at 5600RPMs - why? (8krdline)
vtech vtec, whatever. i dont type about engine parts every day. and is VTEC a word?
after it is warmed up it will reach about 6200RPM before reaching its rev limit. not a big deal i guess, sounds like.
what was "limp mode" again? lol
Old Jul 23, 2005 | 12:38 PM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboME &raquo;</TD></TR><TR><TD CLASS="quote">vtech vtec, whatever. i dont type about engine parts every day. and is VTEC a word?
what was "limp mode" again? lol</TD></TR></TABLE>
Wow.........
Please don't breed and do the rest of the world a favor.
Old Jul 23, 2005 | 12:41 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboME &raquo;</TD></TR><TR><TD CLASS="quote"> and is VTEC a word?
no its not really a word....it stands for Very Tall Engine Coolant
Old Jul 23, 2005 | 12:44 PM
transpar_nt's Avatar
Vtec is an acronym for Variable valve-Timing and lift Electronic Control. VTECH is a phone. I won't **** on you over the error, but it does get really annoying. You will get flamed A LOT if you spell out VTECH instead of VTEC.
Notice the difference?
Old Jul 23, 2005 | 12:46 PM
EJ1_203's Avatar
check ur oil sometimes when ur oil is low v-tech wont engage it is a safety feature that the brilliant pepole at honda came up with
Old Jul 23, 2005 | 12:48 PM
Default Re: Red Lining at 5600RPMs - why? (eg94civic)
ITS ******* VTEC!!! I just explained this. Geez...
Old Jul 23, 2005 | 12:50 PM
Kyles ej1's Avatar
Default Re: Red Lining at 5600RPMs - why? (transpar_nt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt &raquo;</TD></TR><TR><TD CLASS="quote">ITS ******* VTEC!!! I just explained this. Geez...</TD></TR></TABLE>
who cares its against the rules anyways.
- Keep the thread ON TOPIC. If a member asks where the VTECH solenoid is on his or her car, just answer. No need for the VTECH phone pictures, no need for 20 posts calling him a noob and telling him how VTEC is spelled. Honestly, it’s not that important. Answer their question and then get on with your day.
Old Jul 23, 2005 | 12:55 PM
battle951sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg94civic &raquo;</TD></TR><TR><TD CLASS="quote">check ur oil sometimes when ur oil is low v-tech wont engage it is a safety feature that the brilliant pepole at honda came up with </TD></TR></TABLE>
w0w u must be related to that guy turboME ^^^
Old Jul 23, 2005 | 02:06 PM
Default Re: Red Lining at 5600RPMs - why? (93ejay1)
My first post was all nice and polite. My second one was not b/c i just finished explaining it.
Old Jul 23, 2005 | 02:23 PM
Punker1234's Avatar
doe sit misfire? idle correctly? check oil it could be low. also, check ur ignition wires and spark plugs. I recently had water above my spark plug and it ruined my wire, so my car wouldn't idle properly and it would bog and misfire all crazy goodluck
Old Jul 23, 2005 | 02:31 PM
turboME's Avatar
i was being humorous by pointing out the ERROR in saying that vtec was a word because its NOT. if we are going to be so grammatical!
and again.. as mentioned, lets keep to subject and not flame all day. you are not that special ... really.
Modified by turboME at 3:56 PM 7/23/2005
