HELP!!!! car wont turn over, and i have to be at work in 2 hours.
Ok so last night i left my CD player on cuz the dick head to wierd it befour i got the car didnt wire it right. Came out of the movie and the car started up but took a min. That was the last time it started without a problem. Got the car almost home and it dies when i pused the cluch in. Had to jump start it to get home, now this morning i bought a new battary thinking logicaly that thats what it would be. But the car dosnt turn over, Check engin light comes on for about 2 sec. when i try ot turn it over. Someone please help me. Just guide me somewhere cuz i dont wanna have to buy a starter and find out its the dizzy. or visa versa. SOMEONE!!!!fdjakfjdaklfjdklajfkldajfkl FUNK!
possibly an alternator?
edit** actaully you should probably do the steps.
Check for spark, fuel any codes...do it quick so we can help you
how can u assume that there is no spark just because it wont turn over...does it juist click when u try to start it or does it just keep cranking without catching....lift up the carpeton the passenger side kick panel and u will see ur ecu...there will be a red light blinking...
to tell what code its throwing is quite easy..for every long blink add ten ..and for the short blinks add 1...lets say it goes like this !......!.!.!...that would be code 13...!......!.......!.!. that would be 22...its pretty simple...when u find out what code its throwing lmk...i will help u out
make sure that the cd player is not hard wired directly to the battery, if it is then it will drain you battery all the time. this happened to me back in the day and it died on me . all i did was re-wire the power wire from the fuse box, it was wired that way when i bought the car and died on me the first time i drove across town......... peace out
Ideal
Nov 6, 2002 09:47 AM
