heater/ac only works on settings 3 and 4
Old Jul 23, 2005 | 04:23 AM
heinrich schnitzel's Avatar
Default heater/ac only works on settings 3 and 4
my air and heat only blows on the last two settings. anyone ever had this problem and have an idea of what it could be? thanks in advance.
Old Feb 27, 2006 | 09:22 PM
Touch's Avatar
Default Re: heater/ac only works on settings 3 and 4 (heinrich schnitzel)
bump... arise from the dead... mine only works on 4... What could this be?
Old Feb 27, 2006 | 09:23 PM
biggnutz123's Avatar
Default Re: heater/ac only works on settings 3 and 4 (Touch)
probly bad heater switch. cheap fix!
Old Feb 27, 2006 | 10:37 PM
94hatchling's Avatar
Default Re: heater/ac only works on settings 3 and 4 (biggnutz123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggnutz123 &raquo;</TD></TR><TR><TD CLASS="quote">probly bad heater switch. cheap fix! </TD></TR></TABLE>
exactly. there is are step resistors which limit the amount of current is sent to the blower depending on what setting it is on. if you can get the climate control out of a civic at the salvage yard for a good price, it would probably be the easiest and quickest way.
Old Feb 27, 2006 | 11:11 PM
nello a.'s Avatar
i would like to see exactly where these parts are in the climate control(resistors). i dont remember seeing anything in there(electronic looking)&lt;technical term
Old Feb 28, 2006 | 10:33 PM
Default Re: (nello a.)
ok so i was wrong. so used to working on chevy's here at school. its located on the blower motor itself.
here is a link to a related topic that shows where it is located and how to fix it.
https://honda-tech.com/zerothread?id=1542677
Jaxis
11
Jul 20, 2016 06:50 AM
Decaf
May 13, 2008 10:02 AM
b18bfreak
Mar 2, 2004 03:52 PM
B2FiNiTY
Sep 1, 2003 05:29 PM
