heater/ac only works on settings 3 and 4
my air and heat only blows on the last two settings. anyone ever had this problem and have an idea of what it could be? thanks in advance.
Re: heater/ac only works on settings 3 and 4 (biggnutz123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggnutz123 »</TD></TR><TR><TD CLASS="quote">probly bad heater switch. cheap fix! </TD></TR></TABLE>
exactly. there is are step resistors which limit the amount of current is sent to the blower depending on what setting it is on. if you can get the climate control out of a civic at the salvage yard for a good price, it would probably be the easiest and quickest way.
i would like to see exactly where these parts are in the climate control(resistors). i dont remember seeing anything in there(electronic looking)<technical term
Re: (nello a.)
ok so i was wrong. so used to working on chevy's here at school. its located on the blower motor itself.
here is a link to a related topic that shows where it is located and how to fix it.
https://honda-tech.com/zerothread?id=1542677
b18bfreak
03-02-2004 03:52 PM
