10 newton meters sounds like a small amount for cam cover bolts
Old Jul 22, 2005 | 10:53 PM
redpeppers's Avatar
Default 10 newton meters sounds like a small amount for cam cover bolts
7 foot lbs seems a lil loose to me for the cam cover bolts. the service manual states to torque to that weight. What do u think?
Old Jul 22, 2005 | 11:00 PM
mingbling96's Avatar
Default Re: 10 newton meters sounds like a small amount for cam cover bolts (redpeppers)
the 8mm boltes that require a 10mm socket are about 7 ft/lbs. usually for those, they are "by feel" torque, meaning i just torque it with a 10mm wrench by feel. If you're talking about the cam cam bolts, the ones that require 12mm sockets, those are 19-20 ft/lbs and you do need a torque wrench for that.
Old Jul 22, 2005 | 11:02 PM
redpeppers's Avatar
Default Re: 10 newton meters sounds like a small amount for cam cover bolts (mingbling96)
cool thanks....i went ahead and torqued them to spec.....to be one the safe side.
Old Jul 22, 2005 | 11:24 PM
LSvtec03's Avatar
they snap easily. don't over torque them. i always just tighten them as hard as i can with my left hand choking up on the ratchet (i'm right-handed).
Old Jul 22, 2005 | 11:26 PM
redpeppers's Avatar
Default Re: 10 newton meters sounds like a small amount for cam cover bolts (LSvtec03)
it is funny u say that cause i did snap one.....i just replaced it and went on.
Modifiedinteg
Dec 14, 2003 10:06 PM
cracker099
Apr 23, 2003 09:58 AM
FitCRX
Feb 5, 2003 11:47 PM
