Timing belt question about a 98 accord v6
I was wondering how much people have paid to get their timing belt changed on their late model accord 6 cylinder motors? also if anyone is interested or knows of a good shop in the cleveland ohio area i am willing to pay for an installation of a new timing belt, water pump, and tensioner. Thanx guys
i paid 50 dollars for a new timing belt, but it was no charge on installation cause i got a new water pump the same time...because they had to take the belt off anyways, and they just stuck a new one on...i think for me to get it done at a dealership was 900$, but it was covered by a warranty so i ended up paying like 200...I dont know if that helps ya cause i m here in washington, but whatever!
:::christianne
:::christianne
I paid $500 for timing belt, water pump, and I think tensioner. I think its near $500 at the dealership too. Dont think it was $900. I had a Honda-Acura specialist shop in the falls install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">I paid $500 for timing belt, water pump, and I think tensioner. I think its near $500 at the dealership too. Dont think it was $900. I had a Honda-Acura specialist shop in the falls install it.</TD></TR></TABLE>
where did you get your timing belt done i see your a local guy. I called the dealership they want 900
900 dollars way way too much money for t-belt kit,,,,,,,,,include belt, pump, coolant, tensionser and outer belts ......more likely 550-650 at a delarship
Dealer just quoted me 500 for a 4cyl. so couldn't be much more for a 6.
900 WAAY TOO HIGH.
Local garage is going to do labor for 125 and got the parts for like 153 or less (but i have connections at a local parts store for cost.
900 WAAY TOO HIGH.
i went to the dealer to get mine done because i was a newb at the time and I didnt really have a trusted mechanic.
645 total with timing belt change, water pump change, and to fix a minor leak in the rear main seal
645 total with timing belt change, water pump change, and to fix a minor leak in the rear main seal[/QUOTE]
a minor leak at rear main seal???? there is no minor leak at rear main seal if it leaks you replace it and to do so you got to pull the tranny out .. did you ask what they fixed exactly??? 645 is about right for t-belt kit,,,,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 »</TD></TR><TR><TD CLASS="quote">where did you get your timing belt done i see your a local guy. I called the dealership they want 900</TD></TR></TABLE>
In Cuyahoga Falls off of Rt.8. Its called Honda-Acura Specialist and thats it I believe. It was $500 for everything. I also had some UR pullies installed for $50 more so it was $550 total.
In Cuyahoga Falls off of Rt.8. Its called Honda-Acura Specialist and thats it I believe. It was $500 for everything. I also had some UR pullies installed for $50 more so it was $550 total.</TD></TR></TABLE>
Thanx for the info, i'm going to call them tomorrow
here in stl huey will do it for 310 on a 4 cyl and that includes replacing all wearable parts that are taken off to get to the t belt like water pump and drive belts
tomcool
May 14, 2007 08:40 PM
