HELP! GSR BEARING ISSUE
Old Jul 22, 2005 | 08:49 PM
white_jdm21's Avatar
Default HELP! GSR BEARING ISSUE
Alright I have 95 gsr block running oversized itr pistons and jdm itr rods now when buying main & rod bearings then thrust washers which is better oem or acl?
STANDARD ACL
RACING ACL
STANDARD OEM????
The racing acl can each be bought with the .001 oil clearence worth it or not ... I have done search after search for these find topics but nothing discussings acl's advancement into the .001 oil clearence I would figure this would mess up the fitment and be loose ??? any opinions welcome desperate to find the right bearings for a motor I have been building quite sometime and don't want my money to go to waste ...
Old Jul 23, 2005 | 08:19 AM
CHEETAH's Avatar
Default Re: HELP! GSR BEARING ISSUE (white_jdm21)
use the OEM bearings and have your machinist measure crank rod journals vs. rod big bore diameter to determine the clearance for spec for the ITR since you cannot easily tell hwo to match ITR rod with GSR crank from the stamped codes.
Greg
Old Jul 25, 2005 | 07:17 PM
Default Re: HELP! GSR BEARING ISSUE (CHEETAH)
bump thanks
stumpyf4
10
Jul 16, 2008 01:31 PM
civicracer1600
Feb 22, 2006 04:22 AM
96redgsr
11
Dec 29, 2005 01:19 PM
reditr
Jan 17, 2004 12:39 PM
DC2R714
Jun 24, 2003 06:02 AM
