clutch problems what are some common for cable type?
Old Jul 22, 2005 | 07:53 PM
alexsracing's Avatar
Default clutch problems what are some common for cable type?
what are some common problems with crx clutches, other than the cable stretching?
Old Jul 23, 2005 | 12:22 AM
Default Re: clutch problems what are some common for cable type? (alexsracing)
bump
Old Jul 23, 2005 | 01:38 AM
Nerologic's Avatar
and the clutch cable snapping
well i had an ACT though...
Old Jul 23, 2005 | 04:52 AM
65stang90crx's Avatar
Default Re: clutch problems what are some common for cable type? (Nerologic)
Another common CRX problem is the clutch pedal bracket busting...This is a design flaw, keep your cable in good repair and you shouldnt have to worry about this though. Ive been through my original and 2 new ones.
Old Jul 23, 2005 | 11:55 PM
anything that would cause the clutch to not fully engage?
Old Jul 24, 2005 | 06:42 PM
bump
Old Jul 24, 2005 | 11:17 PM
CRXDrew's Avatar
sqeaky pivot on the pedal.
Old Jul 25, 2005 | 06:15 AM
gmptep1's Avatar
Default Re: (alexsracing)
yeah, not being adjusted
Old Jul 25, 2005 | 11:40 PM
up
Old Jul 27, 2005 | 10:26 AM
anything that would cause clutches to slip, even new ones
Old Jul 27, 2005 | 10:55 AM
g2tegsown's Avatar
Maybe your problem is not the clutch... How is the condition of your flywheel? Maybe it needs a resurfacing.
Old Jul 27, 2005 | 12:40 PM
FOrSfEd's Avatar
Default Re: (g2tegsown)
ef's throw out bearings are terrible and sometimes cause lots of problems.
Old Jul 27, 2005 | 10:14 PM
flywheel was resurfaced, tryed a 6 puck off e-bay which worked for 3 months then started slipping, then i resurfaced the flywheel and put a new clutchmasters stage 3 segmented kevlar and it slips on first try after cruising it for 50 miles to settle it in.
what are some problems the throwout bearing can cause other than noise
Old Jul 28, 2005 | 05:59 AM
zccr-xsi's Avatar
are u breaking in your clutch right?just thought i would ask
Old Jul 28, 2005 | 06:06 AM
You know there is an adjuster there in the engine compartment that you can tighten or loosen you clutch cable right?
Old Jul 28, 2005 | 06:59 AM
yeah, I even put in a new cable.
the 6 puck dosn't really need a break in, and the kevlar from clutchmasters i broke in like they said to
Old Jul 28, 2005 | 09:27 AM
djsire's Avatar
i have the same problem!!!!! sometimes it slips. and sometimes it grabs. usually in the morinning it slips . then after driving around a while it grabs. wtf
Old Jul 28, 2005 | 10:33 AM
fourthgenhatchB17's Avatar
Default Re: (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">ef's throw out bearings are terrible and sometimes cause lots of problems.</TD></TR></TABLE>
?, Never had a problem with them.
Old Jul 28, 2005 | 11:26 AM
it will hold allmotor, but not boost anymore.
which really sux , it should hold
Old Jul 28, 2005 | 10:12 PM
ttt
Old Jul 29, 2005 | 05:01 PM
bump
Old Jul 29, 2005 | 05:06 PM
RCautoworks's Avatar
Default Re: clutch problems what are some common for cable type? (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">Another common CRX problem is the clutch pedal bracket busting.</TD></TR></TABLE>
Design flaw, says who ? I have not seen a stock Honda's clutch bracket break. I just replaced a pedal assemble because the pedal broke. He had an act clutch setup, but the cable actually twisted around and around, making it harder and harder to engage the clutch. And after awhile the pedal broke.
Old Jul 29, 2005 | 05:09 PM
donuttes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">flywheel was resurfaced, tryed a 6 puck off e-bay which worked for 3 months then started slipping, then i resurfaced the flywheel and put a new clutchmasters stage 3 segmented kevlar and it slips on first try after cruising it for 50 miles to settle it in.
what are some problems the throwout bearing can cause other than noise</TD></TR></TABLE>
when i bought my exedy organic, it said to break it in for at least 750 miles.....maybe 50 wasn't enough
Old Jul 29, 2005 | 05:26 PM
Turbo Dan's Avatar
i have an act flywheel and centerforce clutch and pressure plate and its never been able to spin the tires into second gear but it held boost really well, but a few days ago it started slipping under heavy load, but some clutch cable adjustment fixed the problem (loostened the nut) and it seems to hold now, although it still doesnt bite when i shift to second.
Old Jul 29, 2005 | 08:47 PM
I've loosened it to the point where the gears don't want to go in , and no dice
