white smoke on muffler
Old Jul 22, 2005 | 05:34 PM
marc-111's Avatar
Default white smoke on muffler
i got a 95 GSR problem is when i am on high RPM and when it hits vtec a thick white smoke comes out of my muffler and a black spots on my rear end
i did a compression test on the head cylinder 1. 235 2. 240 3. 240 4. 238
there is no oil leakage but still once in a while i add oil on my car,
BTW i changed all my gaskets and seals like head gaskets, cam seals and vtec gaskets,
what could be the problem?
Old Jul 22, 2005 | 06:59 PM
Backk InTheDA's Avatar
I hate everything
Default Re: white smoke on muffler (marc-111)
When your blowing white smoke, its usually a head gasket. Did you change it, or a shop? Was it torqued correctly? Is there any oil leaking from the head?
How long has this been going on for?
Good luck
Old Jul 22, 2005 | 07:10 PM
marc-111's Avatar
Default Re: white smoke on muffler (BuilttB18C5)
yup a reputable shop changed it, no oil leaking from everywhere
it's been 3 months now
the engine runs strong the only problem it the thick white smoke coming out when it hits vtec and the black spots on my rear end
Old Jul 22, 2005 | 08:26 PM
Stripped Honda's Avatar
99-0104
its most likely the rings going bad .... just take it easy on the engine and it will be fine for a while
Old Jul 23, 2005 | 12:29 AM
apok's Avatar
Default Re: white smoke on muffler (Stripped Honda)
When smoke comes out of your car, does that tell you to "HIT VTECHK"?
Lay off your engine until you get it fixed.
Old Jul 23, 2005 | 04:42 AM
marc-111's Avatar
Default Re: white smoke on muffler (apok)
my car releases white thick smoke when it hits vtec
i did a compression test and the test where good for piston rings to be worn out and i pulled the dipstick while the car is started and there is no smoke coming out
^^^^ this is what people say to me to check if my piston rings are no longer good
Old Jul 23, 2005 | 08:56 AM
CleanLikeJdm's Avatar
Hype-R Stalker
What about the Valve seals?
Old Jul 23, 2005 | 02:37 PM
marc-111's Avatar
Default Re: white smoke on muffler (FlatBlackTeg)
^^^^that is what i think the problem is
Old Jul 23, 2005 | 04:35 PM
ay_dawg's Avatar
My car does the same, it blows white smoke when i'm on vtec. I had my headgasket and valve seals replaced and it doesn't do it now.
Old Jul 23, 2005 | 05:39 PM
marc-111's Avatar
Default Re: (Paolo)
how much did you spend for the valve seals? changed?
Old Jul 23, 2005 | 07:22 PM
AllMotorDan's Avatar
funny this thread just came up cause i have the same problem....lots of smoke passed 6k and black soot on my rear bumper and wing....not to mention i have a white car
Old Jul 23, 2005 | 07:32 PM
marc-111's Avatar
Default Re: (SpoonSirG)
^^^^ same as me same 95 GSR and white car
Old Jul 23, 2005 | 07:41 PM
yup it sucks and i've been searching but don't know what to do. I don't feel like ripping apart the whole engine to find out that its something small or inexpensive.
Old Jul 23, 2005 | 08:25 PM
marc-111's Avatar
i think my problem are my valve seals or piston rings, im still deciding to build my engine (but got no mooooollllaaaaaah!!!! to support) or just change my valve seals and piston rings to oem ones but on the long run i would still build it,
Old Jul 24, 2005 | 05:18 AM
anyone else have some input?
Old Jul 24, 2005 | 05:48 AM
ALMXDUPINTEGRA's Avatar
Running Rich?
Old Jul 24, 2005 | 05:56 AM
yeah thats what i think my car is doing because before i put my intake manifold on my car and my exhaust i never had this problem. it seems like i got this problem when i put the IM on. Im going to the dyno on the 8th so they should be able to tell me if im running rich
Old Jul 24, 2005 | 05:57 AM
JDM-EJ1's Avatar
It's either valve seals or piston rings since we've already ruled out the headgasket and oil leakage.
Old Jul 24, 2005 | 07:43 PM
marc-111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSirG &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats what i think my car is doing because before i put my intake manifold on my car and my exhaust i never had this problem. it seems like i got this problem when i put the IM on. Im going to the dyno on the 8th so they should be able to tell me if im running rich</TD></TR></TABLE>
pm me for the results if the white smoke is gone cause i also got the same setup as yours, IM and exhaust
mafia
Aug 17, 2007 05:58 PM
newtype_civic
26
Jun 6, 2007 10:43 AM
4drITR
May 3, 2006 09:13 PM
marc-111
16
Jul 24, 2005 07:44 PM
NA JDM GSR
Feb 25, 2005 04:22 AM
