car won't crank, but can compression start no problem.....
checked fuses, checked the starter (it works) hearing the fuel pump prime. just when i turn my key it doesn't do anything.... Battery is fully charged, sounds like a ground problem right, but i checked them like a million times.
Only other thing i can think of is ignition switch, any way to test?
The car does run fine, when i compression start it, i am out of ideas
Check your grounds again. I had a very similar problem 2 weeks ago, I checked all of the fuses, ground, etc , then I rechecked everything and noticed that the ground ( I don't know the exact name) that is around the thermostat housing and was out. Reconnected it and the car started fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6 DOHC ED9 »</TD></TR><TR><TD CLASS="quote">Check your grounds again. I had a very similar problem 2 weeks ago, I checked all of the fuses, ground, etc , then I rechecked everything and noticed that the ground ( I don't know the exact name) that is around the thermostat housing and was out. Reconnected it and the car started fine.</TD></TR></TABLE>
checked those again, and had a friend check them to make sure i wasn't missing something
use new ground wires. sand/scrub the contact patch areas. starter selonoid may be working but its not engaging right.. gear worn?, in all the way?, wrong starter?, bad Flywheel missing teeth.
it was a my clutch switch, so i just jumped it, and now it starts wihtout pushing in the clutch. thanks for the info
ok GOD, u wanna fix my clutch pedal assembly that just broke off? haha, looks like i can't go tommorow, this sucks.
it broke up top where it mounts. not even where its bolted down, it broke away from solid metal. I guess my leg is just that strong. haha
