JDM Front with yellow hids in fogs, pics?
im in the middle of my itr conversion and i plan on having yellow hids in the fog section of the headlight and the oem honda hids in the other. i was wondering if anyone has any pictures of this setup? thanks.
I would advise against it. The factory fog lamp housing is designed to use an H3 bulb with a horizontal filament. Typical HID capsules have a vertically positioned arc. Because of this, the resulting beam pattern will likely be less than optimal, which is not something you want on fog lamps (or any vehicle lighting for that matter).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragingSPAM »</TD></TR><TR><TD CLASS="quote">i thought the fog section already had a yellow shroud over the bulb so you dont need a yellow bulb</TD></TR></TABLE>
you are correct. But...some people buy yellow bulbs anyway....
Greyout
Sep 23, 2003 10:03 AM
