ITR vs. GSR master cylinder and brake booster
Old Jul 22, 2005 | 02:06 PM
nikolai.'s Avatar
Default ITR vs. GSR master cylinder and brake booster
I know there have been a million posts about this already. I have read all of them. Does anyone know definatively if there is any real performance advantage to running the ITR over the GSR?
My EG will be a dedicated autox/HPDE car. I will need to stop very hard, very fast over and over. It's ok if i have to bend and reflare some lines.
Also my car is non-ABS. Does this have any effect on using an ABS 1" MS?
Old Jul 23, 2005 | 06:52 AM
nikolai.'s Avatar
Bueller.............................Bueller....... ...........................
Old Jul 23, 2005 | 07:12 AM
Luserkid's Avatar
Default Re: (NB)
MC/BB from an ABS car is the same as a non ABS car. It matters at the PV and on.
I think all integra's that have the 1 inch MC use the same, because i got a LS 1'' MC and it looks exactly like my friends ITR 1''
Old Jul 23, 2005 | 09:08 AM
LeftCorner's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">MC/BB from an ABS car is the same as a non ABS car. It matters at the PV and on.</TD></TR></TABLE>
non-ABS uses 15/16" MC and ABS uses a 1" MC. The brake boosters have different part numbers so they most likely are not interchangeable.
Old Jul 25, 2005 | 01:33 PM
nikolai.'s Avatar
Anyone else have anything to add?
Is there any performance advantage to an ITR booster and master cylinder over a GSR system?
Old Jul 25, 2005 | 02:03 PM
superdupervtec's Avatar
Default Re: (NB)
Itr is much better, I have done this swap in an eg.
The booster is bigger and the master is different, it gives you more mechanical advantage.
It fit's 100 %.
All you have to do is cut and reflare one of the lines cause it's on the opposite side and has to be relocated, I know this had to be done when going from a gsr/sir to a type r master booster setup.
Old Nov 11, 2006 | 11:20 AM
WHAT TEH's Avatar
Default Re: (superdupervtec)
i just picked up a supposedly IT-R (definitely 1") MC w/BB for m EH3 (EG). tha connections for tha lines on tha MC are fortunately on tha same side as my orginal stainless steel lines. however, tha connection closer to tha BB has a larger opening than tha orginal 3/16 brass fitting.
what did you guys do for that conversion? i can't find a reducer in metric or that brass fitting in metric anywhere anywhere. my only chance of findin' it is if i were to go to a junk/salvage yard, which tha closer one is 2 hours away. unless, you guys can suggest somethin' else for me.
thanks,
_taF
Old Nov 11, 2006 | 11:57 AM
k20EP3's Avatar
Default Re: (tallazzFilipino)
ITR is always better hands down in any situation, you cant get anything better from the factory then itr stuff so id say go with that, but a gsr would be just as good for you needs. i had a vx with gsr complete swap and did a bunch of auto x's and lots of track events. the braks were awsome!
Old Nov 11, 2006 | 01:22 PM
WHAT TEH's Avatar
Default Re: (k20EP3)
one of tha two hard lines in my hatch won't screw into tha MC because it's too small. what did you guys do for this?
_taF
Old Nov 11, 2006 | 03:11 PM
lek9l's Avatar
ABS MC has a bigger line going to rear, not the same.
Old Nov 12, 2006 | 07:31 AM
WHAT TEH's Avatar
Default Re: (lek9l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lek9l &raquo;</TD></TR><TR><TD CLASS="quote">ABS MC has a bigger line going to rear, not the same.</TD></TR></TABLE>
so, i guess none of you guys ran into this problem? i can't find a frikkin' reducer anywhere, especially for metric. this is a pain in tha azz.
_taF
Old Nov 12, 2006 | 08:16 AM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20EP3 &raquo;</TD></TR><TR><TD CLASS="quote">ITR is always better hands down in any situation, you cant get anything better from the factory then itr stuff so id say go with that, but a gsr would be just as good for you needs.</TD></TR></TABLE>
GSR and ITR booster/brake master cylinder from 98-01 are the same.
Old Nov 12, 2006 | 08:51 AM
WHAT TEH's Avatar
Default Re: (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">
as far as tha MC's go and what's visually obvious, aren't tha reservoirs different? tha IT-Rs hold more.
_taF
NeverOut215
May 4, 2013 04:24 PM
juba_x
Jan 21, 2011 09:51 PM
2 0 3
Suspension & Brakes
Feb 25, 2006 10:35 PM
phantom_sol
Sep 28, 2003 08:53 AM
