what is the stock fuel pressure for 91 civic
Old Jul 22, 2005 | 01:19 PM
racingant's Avatar
Default what is the stock fuel pressure for 91 civic
i've just dropped in a b16 swap in 91 civic, i think it not getting enough fuel. i want to check the fuel pump pressure, what psi should it be at. will a stock 91 civic pump be able to run a b16 motor that was converted to obd1
Old Jul 22, 2005 | 01:59 PM
eda6's Avatar
Default Re: what is the stock fuel pressure for 91 civic (racingant)
You should see 35-41 psi with the vacuum hose disconnected from the fpr. The 91 civic fuel pump shouldn't have any problems supplying enough fuel to your b16. I've ran 48 psi on my 88 civic fuel pump and it was fine.
Old Jul 24, 2005 | 09:31 AM
racingant's Avatar
Default Re: what is the stock fuel pressure for 91 civic (eda6)
i get 45 psi with the vacuum hooked up is that good
Old Jul 24, 2005 | 12:01 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">i get 45 psi with the vacuum hooked up is that good</TD></TR></TABLE>
that's too high imo.
What's the pressure with the vacuum line disconnected?
Look for a restriction in the fuel return line first. If that's not it try another fpr.
Old Jul 24, 2005 | 12:04 PM
90sohcHATCH's Avatar
31 stock
B16-CRX
Oct 4, 2010 04:32 PM
Mref813
Dec 31, 2009 04:43 PM
festivagt
Jan 15, 2006 12:29 PM
Propulsion
Sep 16, 2004 10:37 AM
b00stedbyFastrax
May 30, 2004 01:18 AM
