code15 not ignitor?? wiring??HELP
ok i have a 91 crx s1 with a b16a swap.. the car will not start. after working a few lil things out . the only code im throwing is code15 , i put a know working ignitor in the dizzy. nothing. still throwing 15 after trying to turn the car over 3 or 4 times.
i start checking voltage. . volts at the dizzy plug are good. and volts at A18 are good (around 10). then i check B15 and B17. which i should getting around 10 volts aswell and im getting like 17volts?? i look through the harness i did not see any cuts or splices in the visable areas of the wires..
. what should i do????
thanks alot.
thanks alot.
The voltage should always be 12v+
It should NEVER EVER spike to 17v+
And if it's 10v+ your battery is shot.
And you don't check for voltage on wires that provide signals to the ECU.
You check continuity. search google for the definition of continuity if you don't know it and also search for how to use a volt meter.
importboi22
11
Jun 22, 2004 01:10 PM
detailer67
Apr 22, 2004 08:10 PM
