Y8 throttle body on Z6???
i read a post saying its possible but u have too plug some lines. Which ones are these, i have a killer deal on a maxbore.com y8 throttle body , any pics or descriptive material would be a great help, searched but only came up with inconclusive results, thnx in advance
Modified by EG1racer at 3:07 PM 7/22/2005
The bolt pattern for the t/b is the same, but the Y8 doesn't have that fast idle valve thing on the bottom like most OBD-I t/b's I've seen. I would just bypass the coolant lines to the t/b entirely if it doesn't get below freezing where you live though.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">The bolt pattern for the t/b is the same, but the Y8 doesn't have that fast idle valve thing on the bottom like most OBD-I t/b's I've seen. I would just bypass the coolant lines to the t/b entirely if it doesn't get below freezing where you live though.</TD></TR></TABLE>Who needs a FITV anyway. EJ2 with JDM B16A obd1 here. Used a TB off a DA teg that has the FITV on the IM. No FITV here, no problems either..
_HANS
18
Jun 13, 2024 09:49 PM
EKMIKEY27
Dec 7, 2010 11:11 AM
TurboGoKart
Sep 30, 2009 02:53 PM
92integra_gs
May 31, 2005 02:53 PM
