idle surge trouble ?? need help its got to go 300miles tonite
ok i was puting on a wet nos kit. so i have had my ecu chiped for 3 degress retard on the timing and disable the o2sensor.(p28). any way i tried taping the fuel rail for the fuel for the wet kit but it leaked on the way home. i hit it llike may a 3 times in like 1-2 second burst. and then all of the sudden it went crazy and started idleing at like 4 grand. so i bearly made it home. the next day i put a new rail on it and put it back together without the nos. then it stared to do it agian once i got the new rail in so i took out the chip so it would run limp mode. because it was only idleing at 2 grand on limp mode. so then i got a p06 non vtec ecu and tried it it runs fine other than the idle surge from 1-2 grand. it also makes like a wining noise its not a vacum leak though not sure whats wrong. i also put whole can of seafoam in the engine and the gas to clean it out. not really to much of an affect.
thanks
nick
thanks
nick
chuckd05
Aug 26, 2002 11:13 AM
