cam question
Old Jul 22, 2005 | 07:40 AM
type_r_jon's Avatar
Default cam question
ok so I've ordered my skunk 2 stage 2 cams for my R. The rest of the engine is stock. I'm debating gettin the cam gears too. Is this a must? How mcuh more power will I realistically get out of advancing or retarding the time. I just don't want to spend more money than I have to.
thx fellas
Old Jul 25, 2005 | 05:00 AM
type_r_jon's Avatar
Default Re: cam question (type_r_jon)
anyone?
Old Jul 25, 2005 | 09:05 AM
Bbasso's Avatar
get on a dyno and find out. Toooo many variables in this question, and don't try to narrow it down or ask for an estimate. Bring your car to a shop that has a qualified tuner and proper equipment and then let us know. (if you want)
Old Jul 26, 2005 | 04:47 AM
type_r_jon's Avatar
Default Re: cam question (Bbasso)
thanks rob. will do
Old Jul 26, 2005 | 09:35 AM
Viper8L488's Avatar
I agree with what was said above. Take it to a tuner and let us know.
Just to give you a little incentive, the most I have seen anyone get from advancing the timing on a stock block ITR was 10whp and 7 ft/lbs. Keep in mind that he had engine management. Hondata is a must with skst2 cams. Also consider some RC310 injectors.
Old Jul 26, 2005 | 10:22 AM
type_r_jon's Avatar
Default Re: cam question (Viper8L488)
ya, I've been told my stock fuel system won't cut it. Do I need a fuel pressure reg and and a fuel rail as well or can I just get away with a better pump and better injectors?
o and the guy who i'm buying off is offering me some sk2 retainers and dual vavle springs. Are these that much better than stock? I suppose I might be able to rev a litte higher with better srpings.
Old Jul 26, 2005 | 10:28 AM
KraZyCHOWMEIN's Avatar
Upgraded valve train is a MUST with the skunk2 Stage 2 cams.
Get the valve train he is offering.
What header are you going to run with your setup?
Old Jul 26, 2005 | 10:34 AM
type_r_jon's Avatar
Default Re: (KraZyCHOWMEIN)
4-1 DC Sports 2.25 collecter. I know, I know shoulda got the JDM 2.5.
What about my fuel system?
Old Jul 26, 2005 | 10:38 AM
Get the FPR, Fuel pump and as recommended upgrade the injectors 310's
Old Jul 26, 2005 | 10:46 AM
type_r_jon's Avatar
and chip it as previous mentioned to remap the fuel system ...
anything else?
b16a4
Apr 1, 2007 05:17 AM
endlesswinterco
Apr 22, 2004 08:20 PM
SlowD
Aug 31, 2002 12:16 PM
Big Phat R
Jul 18, 2002 02:32 PM
GSxRated
Jun 27, 2002 12:45 PM
