Cheap B16 Build
I need to know if this setup would work.
B16B pistons
B16 rods
B16 head
Crower stage 3 cams
or Ls crank and rods I want at least 12.0 c/r not more 13 pump gas only
Any other combos would help thanks
B16B pistons
B16 rods
B16 head
Crower stage 3 cams
I was running ctr pistons, I/H/E, skunk2 manifold and made 162whp. With some cams that could easily be 180+whp. I put in a full arp set and it was doing fine until I ripped it out to legally pass smog in cali.
It's definately possible. Omniman made 200whp with a b16a using mostly inexpensive parts. Only god//buddha//whatever knows how he did it though. I think with itb's and some cams my engine could have made 200whp.
Well since I was only on stock cams I was only revving to 8200. With the right cams and valvetrain along with arp components you could probably rev pretty dam high. You should definately balance the rotating assembly if you're going to be revving it high though. Also maybe you should think about using some aftermarket rods like eagles or something that's really not too expensive.
racing_reject_001
20
May 10, 2009 04:38 AM
DRKSol
Jul 7, 2004 10:11 PM
ls95hatch
20
Oct 9, 2003 11:33 AM
