Turn signal lights help!!!
Ok I was working on my car and I changed out my taillights when I put them back on I pinched a wire and it grounded out. I changed two fuses, one under the dash and one under the hood for the hazards. The hazards work, but my turn signal lights still don't work. I checked all the fuses under the dash and none of them are blown. Is there anywhere else I should check? I have a 96 GSR. Help please.
this is actually a common problem that I have seen posted a ton of times on teamintegra and there never really seems to be any solution that ive seen. It always happens when someone takes out their taillights. Did you make sure the wire that got pinched was repaired properly? You may have burnt out the actual plugs themselves (meaning the things the bulbs plug into)
shoot me an email @ shore96teg@comcast.net and Ill send you a copy of the helms manual. That should help you locate anything else that may have blown (eg. relay)
mac_24_seven
Mar 13, 2012 03:34 AM
TheCivicMafia
14
May 15, 2009 03:52 AM
headrec*
Jul 8, 2008 12:16 PM
