Suspension & Brakes Theory, alignment, spring rates....
LCA bolt won't budge
Old Jul 21, 2005 | 08:41 PM
civic_speed99's Avatar
Default LCA bolt won't budge
So I was installing my suspension today and I got held up on the read LCA bolt to let the shock drop down on my 99 civic. I finally got it out by unbolting the other end, but I won't be able to get it back in. I even this this with a breaker bar and then an impact wrench. Any ideas on how to get it out.
Just for those who wanna know I got Koni Reds and Eibach Sportlines.
Old Jul 21, 2005 | 09:10 PM
Cory Matthews's Avatar
Default Re: LCA bolt won't budge (civic_speed99)
make sure your turning it the right way. one side you pull and one side you push.
Old Jul 21, 2005 | 09:57 PM
00R101's Avatar
Default Re: LCA bolt won't budge (z6 coupe)
Read the Koni shock install at the top of the forum. Even though its for an ITR the principle is the same. You need to loosen several bolts to get the LCA back in and then use a jack to push the rear suspension into place so you can retighten the other bolts
Old Jul 22, 2005 | 05:22 AM
New day and round two. I'll let you know how it goes. Maybe I'll get some pics.
.colin
Northeast
Apr 13, 2008 09:59 AM
thw_goalie
Suspension & Brakes
Mar 29, 2006 11:08 AM
BLUE EH3
Suspension & Brakes
14
Jun 7, 2005 05:01 AM
JM Performance
Jun 1, 2002 04:44 PM
