tilting turbo for fitment? how much is too much?
Old Jul 21, 2005 | 08:32 PM
90civichbsi's Avatar
Default tilting turbo for fitment? how much is too much?
im getting a custom manifold made and i was curious what is limit for tilting a turbo so that it doesnt starve for oil. 45 degrees? 30 degrees? 20?
the reason i ask is for fitment on my car it would work out best to tilt the turbo so that the intake can run up behid the headlight and the downpipe has very little bend.
i want real knowledge not just some guesses if any one knows. thanks
Old Jul 21, 2005 | 09:20 PM
beepy's Avatar
Default Re: tilting turbo for fitment? how much is too much? (90civichbsi)
As little as possible. I have heard 15° before, but I wouldn't even chance that.
Old Jul 22, 2005 | 03:58 AM
Default Re: tilting turbo for fitment? how much is too much? (beepy)
anyone else?
Old Jul 22, 2005 | 05:54 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">As little as possible. I have heard 15° before, but I wouldn't even chance that. </TD></TR></TABLE>
I've heard that number too so it could be right..hopefully some turbo gurus from Phoenixturbo or something will come in
Old Jul 22, 2005 | 10:02 AM
Default Re: tilting turbo for fitment? how much is too much? (adseguy)
i thought it was about 20 but i want someone to confirm that really knows
what would happen if it was tilted too much? i mean under 45 it would still flow oil but would it jsut starve the compressor side?
Old Jul 22, 2005 | 10:19 AM
dustin's Avatar
You can clock the center housing to point however you want... why does it matter?
Old Jul 22, 2005 | 10:28 AM
adseguy's Avatar
Default Re: tilting turbo for fitment? how much is too much? (dustin)
I think he meant side to side haha
Bailhatch's Avatar
I thought he meant putting one wheel higher than the other. I try to keep it around 5* or less on the stuff i build and about 15* either way on clocking the center.
Old Jul 22, 2005 | 10:50 AM
EJ1 wilcox's Avatar
Default Re: tilting turbo for fitment? how much is too much? (Bailhatch)
In Maximum Boost is says it shouldn't be more than 30 degrees off center, to allow for proper lubrication and oil drainage.
I have seen a few setups that push 30 degrees, maybe even more without any problems. But who knows, it might make the bearings and seals wear out more quickly even if doesn't leak right off the bat.
Old Jul 22, 2005 | 11:23 AM
msmotorsports's Avatar
Default Re: tilting turbo for fitment? how much is too much? (EJ1 wilcox)
I all honestly I don;t think it would matter. If you have proper oil pressure, oil will be forced through the center cartridge no matter how it was mounted.
Old Jul 22, 2005 | 12:28 PM
adseguy's Avatar
Default Re: tilting turbo for fitment? how much is too much? (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">I all honestly I don;t think it would matter. If you have proper oil pressure, oil will be forced through the center cartridge no matter how it was mounted. </TD></TR></TABLE>
Yeah, but oil is drained by gravity only so therin lies the problem.
Old Jul 22, 2005 | 12:59 PM
dustin's Avatar
ah, yeah that makes more sense... hehe.
Old Jul 22, 2005 | 02:53 PM
b/c for best fitment we were gonna tilt the turbo about 35 degrees, but im just afraid i might starve the compressor wheel.. i guess ill see
Old Jul 22, 2005 | 02:54 PM
dustin's Avatar
just drive on a 35degree banked road all the time...
Old Jul 22, 2005 | 10:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">just drive on a 35degree banked road all the time... </TD></TR></TABLE>
ive got it... ill just raise the coilovers on the pass. side to compensate!!
moores55
Mar 28, 2008 12:44 PM
RACEPAK
Jan 22, 2008 05:50 PM
greygoose
Dec 30, 2007 05:23 PM
Exvtec king
17
Jul 10, 2007 11:07 AM
rkeith
Welding / Fabrication
16
Sep 20, 2005 09:38 PM
