PLEASE HELP CLICKING NOISE "GAS KNOCK" MAYBE VALVES? HELP
Old Jul 21, 2005 | 06:45 PM
93CharcoalHatch's Avatar
Default PLEASE HELP CLICKING NOISE "GAS KNOCK" MAYBE VALVES? HELP
i get a clicking "gas knock" type of clicking when the engine is stuggling, such as on uphills.. and only when i am on the gas, its getting louder and louder and more frequent everyday.. Any ideas?? its a stock D15B7
Old Jul 21, 2005 | 07:07 PM
Default Re: PLEASE HELP CLICKING NOISE "GAS KNOCK" MAYBE VALVES? HELP (93CharcoalHatch)
Someone please help i need to know ifs its serious ASAP.. need some opinionsss
Old Jul 21, 2005 | 08:05 PM
opinions would be greatly appretiated
Old Jul 22, 2005 | 07:04 AM
Bump for some opinions and damn its hot out
Old Jul 22, 2005 | 07:52 AM
i did a search and couldnt find a thing
Old Jul 22, 2005 | 09:00 AM
Relic1's Avatar
tune up? (new plugs, new wires, new fuel filter, set timing, reset ECU)
run better fuel
run some seafoam though it
Old Jul 22, 2005 | 09:07 AM
Deemeetree's Avatar
Electrician
Does it sound like coffee beans shaking violently in a coffee can?
Old Jul 22, 2005 | 09:57 AM
Default Re: (Deemeetree)
yes i guess it can be compared to coffee beans in a can.. haha i run 93-94 octane NOTHING else.. let me know some more opinions
Old Jul 22, 2005 | 10:16 AM
thangnhocngheo's Avatar
Default Re: (93CharcoalHatch)
theres 2 thing i can say... if the gas knock like that... then ur backfiring... did you do any mods to ur car? if yes then check ur wiring... if not the it might sound like ur valve mess up... and the valve will sound like everytime you start ur engine you can hear it... and when you gas it.. it goes louder... thats the only thing i kno... good luck
Old Jul 22, 2005 | 10:20 AM
nicehatchy's Avatar
bump for same noise but only under heavy load like when going up a hill. Friend told me i could need a valve adjustment? will try it this weekend.
Old Jul 22, 2005 | 10:29 AM
Default Re: (nicehatchy)
my exhaust doesnt sound normal now either like a sputtery sound .. i think this may be the end ..
Old Jul 22, 2005 | 05:40 PM
bump for some more ideas
Old Jul 22, 2005 | 07:46 PM
disposable's Avatar
bump for same problem
Old Jul 22, 2005 | 07:51 PM
Deemeetree's Avatar
Electrician
How's your timing?
Have you checked if the rattling is coming from the catalytic converter? Sometimes, when the cat is shot, it breaks down and rattles inside of itself.
Old Jul 22, 2005 | 08:04 PM
Evs-One's Avatar
Solbros Owns Me
sounds like detonation or pinging. Usually happens with either too advanced tiuming, too high compression, not enough fuel, or too low octane. Grab a timing light and make sure your timings cool. Adjust if needed, check cam timing, etc.
Old Jul 23, 2005 | 05:18 AM
heinrich schnitzel's Avatar
Default Re: (Evs-One)
definitely sounds like a detonation problem. as described above, you need to check the timing, and a good tune up never hurts either. as the cat converter does rattle when it's broken up (the resonator too) you can check it very easily by getting under the car when it's cold, and grab the exhaust pipe and move it back and forth real quick. if it's bad, you will hear it rattle just like those coffee beans. i can't imagine too many other problems that would cause a knocking like you are describing. when it starts to knock, does the engine buck at all, or is the power delivery still smooth and un-interrupted? if the car starts to buck when it is making the knocking sound then i would say it's definitely detonation problem. as mentioned before, it can be a combo of bad fuel or bad timing. just curious, but have you ever tried to put regular 87 octane in there? sometimes cars are temperamental like people, kind of like how some people need to drink heineken to have a good time, while others work better with Natural Ice. just an idea.
Old Jul 23, 2005 | 08:29 AM
Default Re: (heinrich schnitzel)
timing is fine .. did tune up and same clicky "gas knock" noise and weird exhaust spuddering noise.. no hesitation just clicking.. its definitley inside the motor .. im thinkin about swaping it anyway.. its a good excuse
a2dadamm
Apr 10, 2007 07:56 AM
FuNkDrSpOt
Jan 20, 2006 02:47 PM
Nin2lude
Apr 19, 2005 04:27 PM
chinzoo
Apr 18, 2005 05:28 PM
SteveeeO
Jun 19, 2003 12:35 PM
