Rota GT3 16" with 10.25" willwoods?
Old Jul 21, 2005 | 04:59 PM
FakeJDMEF8's Avatar
Default Rota GT3 16" with 10.25" willwoods?
just wanted to see if they would clear....if anyone knows or has pics that would be amazing...
Old Jul 21, 2005 | 05:29 PM
Bunger's Avatar
Default Re: Rota GT3 16" with 10.25" willwoods? (FakeJDMEF8)
Without a problem, you can fit 11" willwoods under 15" wheels (most of them).
Old Jul 21, 2005 | 08:23 PM
PURPLETERROR aka BIGMATT's Avatar
Im running 11 inch redrilled prelude rotors and modified Itr calipers. They clear my 15x7 gt3's without a problem. You should be fine with the willwoods.
Old Jul 21, 2005 | 09:22 PM
bc_ef8's Avatar
I have 15"x7" GT3. I'm using 11" corrodo rotor and DA caliper. I have to use a 5 mm spacer to clear the wheel weights.
It really comes down to caliper shape and wheel design. Straight spokes tend to leave more clearance. If it says it'll fit under OEM 15" wheels then it'll fit under almost all 15" wheels w/ a 40ish offset with a spacer.
Old Jul 22, 2005 | 04:00 AM
DpSyChO's Avatar
Default Re: (bc_ef8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bc_ef8 &raquo;</TD></TR><TR><TD CLASS="quote">I have 15"x7" GT3. I'm using 11" corrodo rotor and DA caliper. I have to use a 5 mm spacer to clear the wheel weights..</TD></TR></TABLE>
Are you using DA or EX knuckles?
Old Jul 27, 2005 | 12:32 PM
FakeJDMEF8's Avatar
i think EX but it came off my boys EG6 and my car is a CRX Si-90
Old Sep 15, 2005 | 03:34 PM
Lo-Buck EF's Avatar
I have to do the same thing. im using ex knuckles and my calipers jjuusstt catch the wheel weights
Old Sep 16, 2005 | 09:06 PM
FakeJDMEF8's Avatar
but they work with the 5mm spacer? 15s?
Old Sep 18, 2005 | 09:33 PM
FakeJDMEF8's Avatar
still searching for solid answers
Old Sep 22, 2005 | 02:35 AM
Lo-Buck EF's Avatar
Default Re: (FakeJDMEF8)
yes, they will fit with 5mm spacer.
Old Sep 22, 2005 | 03:42 PM
FakeJDMEF8's Avatar
anyone using any other wheels with the big brake kits...like team dynamics or the track r by rota?
Old Sep 22, 2005 | 04:14 PM
CRX Toad's Avatar
I am using the ITR/Prelude Rotors/EX Knuckles and I run Flik Fuel rims and I have about 10 papers worth of space between the weights and caliper.
http://www.edgeracing.com &lt;---Flik Wheels
You can see the clearances here.
Old Sep 22, 2005 | 04:32 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i have the bigger willwood kit with team dynamics, some clearance modification were needed. i can assume the 11" version will fit
stan
Old Sep 22, 2005 | 09:30 PM
FakeJDMEF8's Avatar
what team dynamics..any pics? your casr is the red one?
Old Sep 23, 2005 | 12:48 AM
bc_ef8's Avatar
Default Re: (DpSyChO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DpSyChO &raquo;</TD></TR><TR><TD CLASS="quote">
none of the above. Using the knuckle from my CRX still.
Using the 5 mm spacer, I just barely clear the wheel weights
Old Oct 4, 2005 | 02:34 AM
Lo-Buck EF's Avatar
i have used team dynamic pro race 1 with 11" with no problems.
bc_ef8-are you using a fastbrake bracket to mount the caliper?
Old Oct 9, 2005 | 07:32 AM
FakeJDMEF8's Avatar
i still want to see 16" GT3's on some willwoods! anyone?
Old Oct 9, 2005 | 09:51 AM
GSRCRXsi's Avatar
dude, if 15's will clear, 16's will definitely clear. the answer is yes. you dont need pics, lol.
Old Oct 10, 2005 | 02:30 PM
Lo-Buck EF's Avatar
my ssr type-x need 5mm spacer to clear the caliper, my gt-3s just need to be static balanced so all the weights are on the inside or else i have to run a spacer. a-tech final speeds clear no problem, team dynamics clear, kosi k1 clear
Old Oct 10, 2005 | 07:58 PM
FakeJDMEF8's Avatar
are your GT-3's 15 or 16's?
Old Oct 10, 2005 | 09:54 PM
bc_ef8's Avatar
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">bc_ef8-are you using a fastbrake bracket to mount the caliper?</TD></TR></TABLE>
Yes I am.
and those are 15"x7" GT3
Old Oct 11, 2005 | 02:54 AM
Lo-Buck EF's Avatar
&lt;-----15" as well
Old Oct 12, 2005 | 02:49 PM
Lo-Buck EF's Avatar
i have a question for all gt-3 owners. what size hubcentric rings are you using and where did you get them from?
Old Oct 12, 2005 | 03:18 PM
FakeJDMEF8's Avatar
look like i have 11.75 or 12" willwoods...anyone know if tha 16"GT3's will work....
Old Oct 20, 2005 | 12:22 PM
FakeJDMEF8's Avatar
bump to tha top...someone has the 12" version with some pimp *** 16's on it...post it up...
20vsleeper
Oct 14, 2008 01:23 PM
Sassafrass
Suspension & Brakes
Apr 21, 2008 05:21 AM
audiimportech
28
Jul 12, 2007 08:54 PM
jwogen1
Sep 1, 2004 06:24 PM
