Starting problems!!!
Old Feb 18, 2002 | 09:23 AM
scratchback's Avatar
Default Starting problems!!!
92 civic
When the key is turned to the second position(augsilatry), there is no power. Fuel pump is not priming, no cels, no srs, no pomer to sunroof, nothing!!!
But when I attemp to start it, it fires right up, and dies when the key moves back to the second position. I can hold it in the third position and the car will run, but once I let go it dies.
Some times I will not have this problem until I come to a red light where I will sit for a sec and then it dies. Again I try to start it but same situation. Fires and dies.
Help me out here guys! Im stuck at work and need an answer.
~~Zach
Old Feb 18, 2002 | 12:04 PM
Default Re: Starting problems!!! (scratchback)
ignition switch maybe?!?!?!?!
Old Feb 18, 2002 | 01:41 PM
Perfectionist's Avatar
A very likely cause, given the symptoms. BTW, the switch part is held onto the key cylinder with two phillips head screws. You will need to disconnect the battery and remove the column shroud to get at it though.
TypeRod
Mar 11, 2010 01:24 PM
W0oT
25
Sep 23, 2004 11:21 AM
91hob20hb
Jul 17, 2004 11:16 AM
scratchback
Feb 18, 2002 12:26 PM
scratchback
Feb 18, 2002 12:22 PM
