car is bogging/studdering after...
I changed plugs & wires, fuel filter, cap & rotor, and ignition coils and my car still boggs/studders. It boggs/studders at 2500 rpm's. Please help!!! I want my car up and running smoothly.
If anybody has had this problem please let me know.
Thanks!!!
Thanks!!!
More details... Does it bog when you give it too much gas or when you touch it slightly? In gear or out? Any cels? Then we could give you more help.
I know I want to try running the Seafoam through my car to alleviate my problem that is similar to yours. My car wants to die with too much gas a low RPM'S. My problem however is my cat which is no longer good. So I am throwing a cel. But good luck! Start with the simple ****, then go from there. GOOD Luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraB18C »</TD></TR><TR><TD CLASS="quote">Friend had similar problem, check the injectors</TD></TR></TABLE>
did your friend end up replacing his injectors? how much will new ones cost me if i end up replaceing them?
thanks for the input!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeezer »</TD></TR><TR><TD CLASS="quote">ok dude, so you brought the car to acura and told them to replace cap & rotor because you THOUGHT it would fix the problem..
why didn't you just ask them to FIX THE PROBLEM?</TD></TR></TABLE>
it's called proper maintance "DUDE" all the things that i had done, needed to be replaced. i also searched on bogging and studdering issues and the things that i replaced were recommended to be replaced. all i wanted to know is who else had this type of problem and i got my answer "DUDE"
the thing is the studdering happens in a blue moon, but the bogging happens when im at a decel when the gas is pushed very very lightly @ 2500rpm, i get a lot of gurgleling from my exhaust and when i push on the gas again the car boggs for about a half a second. should i be worried about my exhaust smelling like rotten eggs and it doesn't smell all the time like that.
hope this info helps some more
Modified by GSR515 at 1:59 PM 7/24/2005
sethmoman
Jan 11, 2012 08:44 AM
