Code Help... search but don't understand it
Old Jul 21, 2005 | 11:54 AM
Dropped90Integra's Avatar
Default Code Help... search but don't understand it
Ok, I have a 90 Accord EX, CEL Light comes on sometimes during start up, so it came on this time and I checked the light... well there are 2 blinking lights, the one of the left did 4 fast and 1 slow, thats 41 correct, well that is Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor, what in the world is that? I don't have any problems with my tranny or anything so I'm unsure.
Now, the light on the right, I don't know what this one is, it blinked 8-1-2-7 all with a pause between them which I guess seperated the numbers... Anyone help me with this, I've been getting HORRILBE gas mileage and I think its related.
Old Jul 21, 2005 | 11:57 AM
Default Re: Code Help... search but don't understand it (Dropped90Integra)
Ok, now I found that code 41 is o2 sensor problem... I recently tired going through inspection and I failed for emissions and my poor gas mileage I would say I need a new 02 sensor don't you think? lol... anyone, could someone tell me which one is code 41 and what are the 2 lights?
Old Jul 21, 2005 | 11:59 AM
Nevermind, I read the troubleshooting code wrong... on the site I read 31 and not 41... apparrently it is my o2 sensor and will be fixed tomorrow... anyone know how long I should disconnect my battery to reset the ECU?
Old Jul 21, 2005 | 04:13 PM
honda_kid42's Avatar
diconnect the battery for a couple minutes...i would say 10 or 15 and then reconnect and start the car and let it idle for 10 or 15 minutes without touching the gas pedal...
Old Jul 21, 2005 | 06:17 PM
Default Re: Code Help... search but don't understand it (honda_kid42)
Thanks... thought 10-15 should be enough with it... I hope this thing changes my gas mileage around.... on bone stock motor I'm getting about 16-17 mpg
Old Jul 21, 2005 | 06:29 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropped90Integra &raquo;</TD></TR><TR><TD CLASS="quote">Thanks... thought 10-15 should be enough with it... I hope this thing changes my gas mileage around.... on bone stock motor I'm getting about 16-17 mpg</TD></TR></TABLE>
It will NTM your car will run better. What were your emission results?
Old Jul 21, 2005 | 06:34 PM
Default Re: Code Help... search but don't understand it (.ken)
In the wonderful state of NJ here were my readings
NOx Standard 1323 Reading 1981 FAILED
HC Standard 173 Reading 57 PASSED
CO% Standard 0.98 Reading 0.65 PASSED
So only thing I failed for was the NOx level.... along with the o2 Sensor I'm gonna replaced my cat with a new one that I have laying around... so you think that'll def. help me pass? I got 201K on this car so I know the cat gotta be shot and just today I did a basic tune up... any other tricks to passing emissions?
Old Jul 21, 2005 | 06:58 PM
v4lu3s's Avatar
RTFM
timing and egr come to mind for the NOx.
you may need to drill out the gr ports and clean them
Old Jul 21, 2005 | 07:00 PM
Well I actually just cleaned my EGR today too.... there wasn't a lot of build up on it... I cleaned it the best I could and bolted it back down.... How could I fix my timing? I know my old plugs, the gap was huge... like at least .70mm or something, I gapped my new ones to the .44 so don't know if that'll make a difference
Old Jul 21, 2005 | 07:04 PM
Actually, you know what, when I tired cleaning the port going into the intake manifold, the carb spray I used seemed to just sit there and not go anywhere... could I have blockage... just farther down? How easy would it be to pull the manifold back or off?
Old Jul 21, 2005 | 07:05 PM
The_Todd's Avatar
Farts in the shower
Unfortunately an engine designed and tuned to produce low CO and HC produces high NOx The hotter an engine runs the more power it delivers, the more NOx it produces.
Late Model vehicles operate with a very lean A/F mixture so the NOx is very high and a "three way Catalyst is incorporated converting CO, HC and NOx.
A device called the E.G. (Exhaust Gas Recirculation) Valve was designed to lower the combustion temperatures by recirculating exhaust gasses back into the combustion chamber.
High NOx on driving Test
- Inoperative or ineffective EGR (Exhaust Gas Recirculation) system
- Excessive lean air/fuel ratio
- Inoperative or missing catalytic converter (three way catalytic)
- Excessive spark advance
- Faulty Thermostatic Air Cleaner (TAC) system
- Defective computerized engine management and/or Oxygen sensor
- Engine Deposits (Carbon)
- Engine Mechanical defect(s)
I would say change your cat and also do this DIY and you WILL pass on your nox: http://home.comcast.net/~em-engineering/T2T013.pdf .
Old Jul 21, 2005 | 07:23 PM
hmmm... after reading that thing, I cause I didn't clean the right thing... I cleaned a little tower lookin thing held on by 2 12mm bolts and has a diaphram thing in it. So I gotta clean out where those little dots under my fuel rail? I just checked and there's 6 of them? I guess that correct and I just follow the DIY
How would I be able to tell if I have the removeable ones BTW... I saw 6 holes not 4 and the plugs look just like the one in the picture that say 90's don't have em
Old Jul 21, 2005 | 07:31 PM
The_Todd's Avatar
Farts in the shower
Yes those plugs usually need to be tapped and drilled so where you can have access to them in the future. Honda made the oem ones so where they weren't 'removeable' but that isn't anything a drill and tap set won't fix . Its weird because some 90-93 accords have 6 some have 4...either way, follow that DIY and clean out the egr .
Old Jul 21, 2005 | 07:35 PM
Cool... I know what I'm doing tomorrow... so all I gotta do is clean that little hole and thats it? You'd think there'd be more or something to it
Old Jul 21, 2005 | 07:37 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropped90Integra &raquo;</TD></TR><TR><TD CLASS="quote">Cool... I know what I'm doing tomorrow... so all I gotta do is clean that little hole and thats it? You'd think there'd be more or something to it</TD></TR></TABLE>
Yep thats it man...very simple yet VERY effective .
Post up some results so we know we helped .
Old Jul 21, 2005 | 07:38 PM
Sure will... gonna post up some pics too
AI95GSR
Feb 4, 2015 02:42 AM
samuel_gatech
Aug 26, 2006 01:56 PM
illmatic1085
May 27, 2006 11:18 PM
silentblackhat
Feb 18, 2005 10:39 AM
cyrixvsp2
Jun 10, 2003 05:02 AM
