How do I take out the speedo gear/assembly from tranny?
Well I have a d16a1 I need to get the speedo out of. On my last 3 attempts (different/spare trannies) I busted the speedo all up.
I live in the land of corrsion so I am sure that may have something to do with it.
As far as I can see I just unbolt the one bolt and it shoudl (therotically) come out.
Also will a d16a6 speedo gear work in a d16a1 tranny?
HELP need to know by tomorrow seeing I am going to buy a different d16a1 tranny since I have no idea how to get it out.
-Shane
-Shane
on the side, on the top? is it just the one bolt holding it in place or is there any type of hidden snap ring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">on the side, on the top? is it just the one bolt holding it in place or is there any type of hidden snap ring?</TD></TR></TABLE>
try on all sides...there should be only 1 screw that goes on top the holds it in place. you could also try prying lightly between the tranny and the s.s. with a screw driver. is the part where the screw goes in aluminum?
yeah there is like a little tab. I think its aluminum. Thats how I broke them before. I was trying to tap it out with a flat head, chisel, etc. and they busted.
From: I told you to wait in the truck in Texas, United States
If you have access to compressed air,use a blower nozzle
to blow out any sand/debris around the top where it goes into the case.
Soak the area liberally with a penetrating oil like PB Blaster..
Lock a small pair of vise grips around the lower larger portain of the sensor
And then work the sensor from side to side to break the seal of the internal o-ring
After the seal is broken,it should pull right out...
thanks for the advice.
just curious where the little tab is that bolts down to the tranny?
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">thanks for the advice.
-Shane
you mean in his picture? He probably broke it off to.
-Shane
I had to go to a junkyard to get a new one for my d16a6. All I had to do was remove the bolt and then pull upwards. It was a battle for the ages, but I eventually won. Visegrips and a strong will...
The slot on the sensor is there,intact...
Look at about 2-3 o'clock on the sensor..
I have also heard of people using a dent puller/slide hammer
if the method described does not work for you.
Pnoyej6
May 17, 2006 07:36 PM
