Brake Question?
Old Jul 21, 2005 | 08:42 AM
madcrossover's Avatar
Default Brake Question?
Is it normal when you pump the brake pedal and the rpm gauge goes higher? I was wondering this and thinking that it maybe be the problem to my low Idle. Also if its not normal and something is wrong would it be Vacuum related? Also only when I turn on the ac my brake pedal travels all the way to the floor. Thanks for the help!
Ive Tried adjusting the idle screw, checked the IACV (Brand New), and messed with the FITV. So any other suggestions? Also the Idle doesnt fluctuate.
Old Jul 21, 2005 | 09:03 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Brake Question? (madcrossover)
Mine does so yeah its normal, I think
Old Jul 21, 2005 | 09:28 AM
Achenar's Avatar
This is normal, and it is because your brakes use pressure from the intake manifold. More brake pedal applied = higher RPM's required to provide pressure.
-a
Old Jul 21, 2005 | 09:56 AM
nighttrain33's Avatar
Default Re: Brake Question? (Achenar)
I concur. ^^^^
-Shane
Old Jul 21, 2005 | 10:33 AM
Default Re:
Ok thanks guys!
jvr
Jun 18, 2021 09:42 AM
Redprelude98
25
Nov 30, 2014 02:15 PM
stripes777
Apr 27, 2008 02:34 PM
RACEPAK
Nov 23, 2006 01:33 PM
Kyoung05
Oct 9, 2006 05:28 PM
