ECU Being wierd.
OK, so what does it mean when you check the ECU for codes and it just stays lit constantly? I thought it might eventually flicker, but it stayed glowing *** red for like 2 minutes.
Thanks...
Thanks...
disconnect all ur sensors....disconnect ur battery/take out hazard fuse whichever.....now reconnect all ur sensors with the battery still disconnected....now reconnect ur battery and start the car....if this does not fix the problem its time for a new ecu
bigslimdog
Mar 30, 2004 03:07 PM
